This has probably been discused to death on here but I hadn't had any real interest in it until I put a down payment on a '99 Dresser last weekend. Gonna pick it up this weekend, I've heard there were issues with the cam bearings and cam chain tensioners? What can be done to correct this, and how would I know what to look for? Is this something that I can do myself (I'm a pretty good shadetree mechanic, do all my own work on the bikes), or is this something that requires a machinist, etc.? Is someone could point me towards some links with discussions on this subject I would truly appreciate it!!
There was a problem with the cam bearings, I have a 99 EG standard, I would guess yours have been updated already, I bought mine a few months ago and the indy replaced the tensioners, my bike had 38k on it, he told me they were already updated. The tensioners on TC engines from 99 to 06 have the spring type tensioners and they would wear out within 30K miles, if they wear out completely and come apart the plastic can ruin the oil pump or clog small oil passages and ruin the engine. If you check them every 5 to 10 thousnad miles they should not be a problem, I was told the second set will last longer since the chain should be smoother from the first set.
How many miles on your bike?
42,000 miles. The guy I'm buying it from bought it from a friend who needed cash and was flipping it to make a few bucks, so I have no idea if the issue was addressed or not. Any way to tell by looking at it? And does anyone have a part number for that HD hydaulic kit? Thanks for the quick replies guys!!
If you have 42k on it I am guessing they have either been changed or updated to the hyd tensioners or gear drive. As far as the other issues I just turned 43k on mine and it runs great, either the other issues have been fixed or yours did not have them. Other then the cam tensioners it is a good engine, I believe 99 to 03 had forged cranks with very good bottom ends. If you want to check just pull off the cam cover, you can clearly see the outside tensioner and be able to see what kind you have.
Awesome, thanks! I'll search around to see if I can find some pics to see what I'm looking at, I'm used to the old school stuff so I would have no idea what to look for!
Fits '99-'05 DynaŽ models, '00-'06 SoftailŽ models and '99-'06 Touring models. Installation requires separate purchase of Spacer Kit P/N 25285-08, Cam Service Kit P/N 17045-99D and Drive Gear Retention Kit P/N 25533-99A.
MSRP US $499.95
You will need the other parts with the kit, see above, plus adjustable push rods to avoid taking the top of the engine apart, I was just quoted $1,300 parts and labor to do the job from my local HD dealer. I would replace the lifters as well while I was in there. People will also tell you to upgrade your cams, I like the way my bike runs and do not need more power, just want it to be dependable and last.
