Pushrod adjustment Q
Old Sep 22, 2012 | 07:32 AM
morleyz's Avatar
morleyz
Default Pushrod adjustment Q
As mentioned in another thread, I have a tapping noise after cam swap with FM adjustable pushrods. Going to readjust the pushrods and make sure everything is right.
Before I started, I have a likely simple question. When I fully shorten the pushrod, do the lifters expand to their max immediately or is there a time I should wait (similar to the bleed down time) before adjusting again?
Old Sep 22, 2012 | 07:56 AM
ColoSpgsMark's Avatar
ColoSpgsMark
I'd give them 30 minutes or so.
Old Sep 22, 2012 | 07:58 AM
stuart1270's Avatar
stuart1270
I believe they take a little time. but not that long maybe a couple of minutes.
Old Sep 22, 2012 | 01:28 PM
Wv7o's Avatar
Wv7o
This might help
Or the S&S Video
http://www.sscycle.com/feature/featureview.php?s_id=38
Old Sep 22, 2012 | 01:55 PM
morleyz's Avatar
morleyz
Those are the videos I followed the first time. Since I'm not going to have the pushrods out for an extended period of time, I was just wondering how long it takes for the lifters to spring back up before I can set them to zero lash and start my adjustment.
Old Sep 22, 2012 | 02:07 PM
FLTRU4ME's Avatar
FLTRU4ME
They expand pretty rapidly. The clacking sound you may hear could be the rocker arm hitting the valve. I have been fighting a sound after cam change and even changed cams and lifters. Some of the cams fall off duration so fast the lifter can't keep the tension on the pushrod. Least this is several engine mechanics response and I can't find anything else it can be. If somebody can help me with this chime in. Mine is most noticable at 2200 -2800 rpms on moderate load.
Edward Brown
Shovelhead
Oct 16, 2012 10:16 AM
BB4xl
EVO
Aug 22, 2011 05:39 PM
Ridetard
Exhaust System Topics
11
Apr 2, 2009 08:42 PM
Ridetard
EVO
Apr 1, 2009 02:31 PM
RIROCKET1
EVO
Sep 23, 2007 06:58 PM
