Fork oil level question
Old Sep 26, 2012 | 11:24 AM
skully1200's Avatar
skully1200
Default Fork oil level question
Can someone explain this to me please? In my 04 service manual, when referring to Road King fork oil there is some confusion (for me anyway). In the section on changing fork oil it basically says drain the fluid, refill with 11.1 ounces, button it back up and get on with your life.
In the section detailing disassembly/reassembly, it states the same 11.1 ounces but then specifies using the oil level gauge to set the fluid height to 5.24 inches from the top of the tube.
Why is the fluid height critical after assembly, but not after a simple fluid change?
Old Sep 26, 2012 | 11:33 AM
jjnoble's Avatar
jjnoble
It's the same, just extra wording to confuse you. Pour it in VERY slowly or it will spill out the top and you won't know how much you spilled so you will have to do it over again.
You don't need anything except to measure the correct amount and a funnel with a tube on it.
Old Sep 26, 2012 | 11:34 AM
Spur56's Avatar
Spur56
Not real critical. Drain good, replace with 11ozs of the fluid you like. Done!!
Old Sep 26, 2012 | 11:36 AM
fabrik8r's Avatar
fabrik8r
It is critical in both situations, the fl/oz measurement is a ball park to make sure there is enough in there to vac down to the proper height measurement. The air gap left in the void is also an element of the suspension. The air is compressible like your springs, too little air space left from too much fluid, can make the front stiff, and too much air space can make it a little soft. With your modified intiminators, set the fluid level to the height measurement in the disassembly/assembley procedure, and that element will be covered, I havent been able to achieve any significant tunability by playing with the fluid level, so I just recommend setting it to the OEM spec.
mkguitar's Avatar
mkguitar
Originally Posted by Spur56
Not real critical. ...
I would say- pretty critical.
the amount of compression, damping and rebound needs to be the same on both fork legs.
Mike
Old Sep 26, 2012 | 11:44 AM
drukanfu's Avatar
drukanfu
Fluid height is most important because of oil thats still in the cylinders, put in the oil slowly. Work the forks a little till you've got about 10.5 oz in, then measure, add a little if necessary, measure...etc.
Old Sep 26, 2012 | 12:06 PM
jjnoble's Avatar
jjnoble
Some people have a tendency to over complicate things, if you are one of them go for it. But it is not necessary. Just drain the old stuff and very slowly pour in the correct amount of new stuff. You could pour in ˝ or ž then wait 10 minutes before pouring in the rest. It doesn’t need to be any more complicated than that.
There is always some oil left in the cylinders but you will leave oil in the measuring cup, funnel and tube as well, so just use the correct amount and it all evens out. Don’t worry about it being off .1 of an ounce one way or the other, the bike will never know the difference and neither will you. If anyone says they can tell the difference in .1 oz they are kidding themselves.
Those drain plugs are tight, make sure you have something to break them loose without stripping the heads. Also the nuts on top have limited space around them, not just any tool will fit in there. An open end or box end wrench works well, if you use a socket it will need to be very low profile.
Old Sep 26, 2012 | 12:25 PM
Spur56's Avatar
Spur56
[QUOTE=jjnoble;10376380]Some people have a tendency to over complicate things, if you are one of them go for it. But it is not necessary. Just drain the old stuff and very slowly pour in the correct amount of new stuff. You could pour in ˝ or ž then wait 10 minutes before pouring in the rest. It doesn’t need to be any more complicated than that.
Those drain plugs are tight, make sure you have something to break them loose without stripping the heads. Also the nuts on top have limited space around them, not just any tool will fit in there. An open end or box end wrench works well, if you use a socket it will need to be very low profile.[/
It is NOt that critical on a touring bike. Only the overly **** ones care about + or - .25" in height. Racing bikes and/ or other types of forks, maybe, but not a Tourer.
Old Sep 26, 2012 | 01:50 PM
fabrik8r's Avatar
fabrik8r
The purpose of a bike's use does not negate the value of a good suspension. A touring bike is meant for long distance riding and casual cruising, I can't think of an application better suited for a well tuned and comfortable suspension. Those on the other end of the spectrum who don't care much about measurin' and torquin, and other nonessential maintenance what nots, are probably correct that they will never know the difference, because they will never achieve peak performance with their shade tree techniques and practices, to know the difference. Skully, since you did your homework on front suspension options and decided on a product that delivers exceptional performance, well beyond stock, I would assume that you're not looking fer a "good nuff" answer. I only recommend the manual quoted fluid height value because its easy to reference and I know it works. I will agree that a little more or less probably won't make a difference, but I also agree that both tubes should be equal, and if you take the time and effort to make them equal you might as well just make it right too, while your at it. You're not doing a generic jiffylube fluid swap on your forks, you are upgrading valving, springs, fluid, and "tuning" your front suspension. "tuning" is not routine maintenance, its a custom adjustment to achieve a specific set of desireable charcteristics for a given set of conditions, and it requires "****" and "overly complicated" procedures and practices to accomplish it.
Old Sep 26, 2012 | 02:03 PM
drukanfu's Avatar
drukanfu
I don't consider it **** or overly complicated to just do it right. Some things accuracy counts, unlike shooting a .22 in a cement silo.
