Grease question
Old Sep 28, 2012 | 02:48 PM
green hd's Avatar
green hd
Default Grease question
I need to grease plunger on on starter solenoid. Anyone know of a good high temp grease to use? Maybe a lithium? Thanks!
Old Sep 28, 2012 | 02:59 PM
Jackie Paper's Avatar
Jackie Paper
Just my opinion but I would not use anything. The service manual calls for Lubriplate 110 However when you Google 110 makes you wonder what they were thinking.(The LUBRIPLATE "100" Series Products are excellent water-resistant lubricants designed for plain bearings, cams, slides and similar applications up to operating temperatures of 150°F. LUBRIPLATE No. 110 is recognized as an outstanding brake lubricant.) From what I have seen this part is not going to wear out moving in and out before something else goes (ie contacts) and when it gets cooking hot the grease tends to dry out, attract dirt and crud and stick the plunger.
Old Sep 7, 2019 | 08:07 PM
Zerk's Avatar
Zerk
Moving parts need grease. I doubt a cheap as harley is they would use if they didn't have too.
Always some grease you don't have. 5 gallon pail, is a bit much.
Old Sep 7, 2019 | 08:55 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
there is always a graphite or other dry film lubricant
Old Sep 8, 2019 | 12:08 AM
Zerk's Avatar
Zerk
Ahh, I don;t think that is what is used in starters. Heavy grease, that is not reapplied.
Old Sep 8, 2019 | 08:39 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Brake grease is a high temperature grease.
Old Sep 8, 2019 | 12:32 PM
Zerk's Avatar
Zerk
That is what I am seeing used by some, and marine trailer grease.
GittinThere
May 11, 2019 10:07 PM
C908
Dec 13, 2013 04:48 AM
Talldog
Sep 24, 2011 02:28 PM
lp284
Jul 29, 2010 09:22 PM
Biff_H
Dec 7, 2008 09:48 AM
