Oil filter
Old Sep 28, 2012 | 06:15 PM
bosshog919's Avatar
bosshog919
Default Oil filter
2012 sg thought I would knock this oil change out in bout 20 mins.. Well tht wuz 2 hrs ago!!! Can't get the damn filter off help!!! Punched a hole in it and still the bastard won't move!!! Now it's ripped down the side and still on the bike!!!
Old Sep 28, 2012 | 06:20 PM
Rickr01's Avatar
Rickr01
If the filter just has a tear and has not lost all of its structural integrity or shape, go to your Dealer tomorrow and pick up the correct filter wrench. It has the cut out for the stator plug and will remove even the most stubborn filter. Sounds like it was over tightened.
baust55's Avatar
baust55
just grab it with a giant pair of channel lock .
Old Sep 28, 2012 | 06:22 PM
2011FXDC's Avatar
2011FXDC
+1 on that..
checkers's Avatar
checkers
Carefully drive a Phillips screwdriver horizontily through filter as close to the base as possible, but not too close to hit the threads in the oil filter adapter, or best yet, borrow or purchase a large Channelock pliers and grab filter as close to base as possible. The OEM original filters are always very tight. Once off install only a K&N oil filter with welded nut on the end. One of the best filters on the market. K171C chrome about $12 bucks. Be carefull not to get into the wiring behind the filter with any tool.
Old Sep 28, 2012 | 06:23 PM
1st 96 ultra's Avatar
1st 96 ultra
as close to the block [ front of filter ] as you can , it won't crush so easy let us know how you make out
Old Sep 28, 2012 | 06:25 PM
bosshog919's Avatar
bosshog919
Try the channel locks!!! Hercules must have put the muthaf@@&$ on!!! Won't budge!!! Headed to dealer tomorrow!!! Dammit!!!
Old Sep 28, 2012 | 06:30 PM
Rickr01's Avatar
Rickr01
Unless its mangled, I have to disagree with the channel locks and get the wrench. But thats your call? Its pretty tight getting in there. You risk damaging something else with large channel locks. Right tool for the right job. Put a little oil on the new filter gasket and turn about 1/4 to 1/2 turn past contact with the base. I have never had trouble getting OEM filters off after the first change.
Old Sep 28, 2012 | 06:32 PM
Rickr01's Avatar
Rickr01
Is it worth $10.00?
http://www.harley-davidson.com/gma/g...6&default=none
Old Sep 28, 2012 | 06:35 PM
Shredding rubber's Avatar
Shredding rubber
I've got the filter wrench that goes on the end of the filter. However if it slips even once it's stretched and no longer works.
I've learned over the years that as soon as the filter reaches the snug point another 1/4 to 1/2 turn and no leaks.
The rubber band oil filter removal tool works too
