trans side cover
Old Oct 1, 2012 | 12:01 AM
vivid103's Avatar
vivid103
6th Gear
Talking trans side cover
im angling out my side cover is there anything ajar to worry about?nothing will pop part that i have to worry about?
make sure it get oil back in it
another is i changed cam cover that will fill up with oil again kinda new to the whole bike thing just check my oil after i have started it ?
thanks
Old Oct 1, 2012 | 06:39 AM
dawg's Avatar
dawg
You can put the bike wheels up on 2x lumber and lean it way over to the left on the jiffy and not have to drain the fluid. Nothing will pop out, but you will have to swap the cable from one cover to the other so make sure the ***** in the ball and ramp assy don't go rolling away on you. Also pay attention that it gets reseated properly.
Old Oct 1, 2012 | 08:05 AM
BIGRED1's Avatar
BIGRED1
Spend the $ and get a manual and a bike lift/jack.
It will make your life so much easier.
Old Oct 1, 2012 | 12:17 PM
rg_dave's Avatar
rg_dave
Nothing will fall out except trans oil. Lean it over like Dawg describes. I use the lip on my garage. You'll need a set of strong ring clip pliers. This is one situation where its best to not use a lift. Long ball allen wrenches allow you to pull the cover without pulling the exhaust. If you have an '09 or up.
Old Oct 1, 2012 | 11:39 PM
vivid103's Avatar
vivid103
6th Gear
i got it changed but my clutch does not feel tight enough how do i fix that i tried tightening the cable didn't do much
Old Oct 2, 2012 | 11:55 AM
rg_dave's Avatar
rg_dave
You need to adjust the clutch. Lots of videos online.
Gringoloco13
Jan 18, 2012 01:26 PM
jimmers1817
Nov 19, 2010 08:50 PM
Born2cure
Oct 29, 2008 02:37 PM
acadien
Apr 11, 2007 09:42 PM
Lightmage
Jun 26, 2006 01:11 AM
