SG to RG conversion question
Old Oct 9, 2012 | 12:10 AM
nlando's Avatar
nlando
Default SG to RG conversion question
For those of you who have done it, I need to know what wiring harness is required that the SG does not have. I have searched but cannot find this info. I believe it is called an inter-connect harness, but I have not been able to find out for certain and don't want to waste cash on the wrong thing.
Thanks.
Old Oct 9, 2012 | 05:53 PM
nlando's Avatar
nlando
No one has an answer? I know there are some of you that have done this, or know of someone that has.
Old Oct 9, 2012 | 06:12 PM
captainron62's Avatar
captainron62
H-D P/n 70274-06 is the interconnect harness you will need.
70423-98 is the headlight harness
google streetglide to roadglide conversion and a pdf file from American bagger w full parts list and instructions will pop up.
Old Oct 9, 2012 | 06:13 PM
skratch's Avatar
skratch
i haven't done it, but thinking about it, it seems that the wiring harness for the sg should be the same one as the rg. unless you're making it an ultra. otherwise, whats the difference between the two other than the headlights?
Old Oct 9, 2012 | 06:38 PM
Redbeard719's Avatar
Redbeard719
I've created a spreadsheet for this conversion, with all the part numbers needed.
You're welcome to it. It has pricing for parts from LSHD1 and New Castle.
LMK. I also have the list from the gang that did this originally. My list has all the newer part numbers, like the brackets for the 2010+ models that move the fairing to accommodate the factory lowers from any touring model.
Old Oct 9, 2012 | 06:52 PM
Redbeard719
Also, since your FLHX is a 2011, you'll probably want the harness that came debuted in 2010.
70274-10 Fairing Interconnect Harness $216.00 (New Castle) Fairing harness for FLTRX Fairing
Old Oct 9, 2012 | 10:50 PM
nlando's Avatar
nlando
Yes, I would appreciate that if you don't mind. I have found an online microfiche for look up of all hd parts, including diagrams and order sheets if you are interested. Let me know, and I will send you my email address by pm.
Thanks.
Old Oct 9, 2012 | 10:54 PM
nlando's Avatar
nlando
It is not the same from what I have read, but have yet to figure out what the harness is for.
Old Oct 9, 2012 | 11:27 PM
Redbeard719
Thanks.
I got your PM, and I'll send it tomorrow (I'm on my iPad).
The harness is the one that lives in the fairing. Same connections, but different wire lengths. It connects all the gauges on one end, and interconnects to the main bike harness on the other end.
The SG harness would not fit.
Old Oct 10, 2012 | 12:37 AM
landslide03's Avatar
landslide03
If i was able to get the fairings used on ebay, about how much does the conversion cost? I love my sg but i am just curious in case i ever want to go to the "Shark Side"
