Figured I'd post in this forum
Old Oct 16, 2012 | 10:57 AM
cjbmustang's Avatar
cjbmustang
Default Figured I'd post in this forum
I figured i'd post this here, as no one has responded over in the correct section of the forum and it also doesn't seem like they do a lot of their own work...
My father's bike is a 2000 road king EFI 88". We loaded the bike up on the trailer, everything was fine. We drove 1300 miles to FL and unload the bike. Start it up to move it into the garage and there's a loud tick. No oil pressure light, plenty of oil in the bike.
Any idea what's causing it? Sounds like a valve-train tick, but can't tell from which head. I will try to find a stethoscope while i'm down here.
someone also suggested a chunk of carbon fell off from all the bumps during transport and is bouncing around in the chamber.
Thanks for any help
Old Oct 17, 2012 | 05:06 PM
Mark98012's Avatar
Mark98012
"No oil pressure light", okay you have oil pressure. Chunk of carbon (to me) is BS. IF it's a slight tick it, get a automotive stethoscope and track it down, just trailering shouldn't cause a problem.
Old Oct 17, 2012 | 05:45 PM
TUCCI's Avatar
TUCCI
The tick was not there before the hauling then?
Old Oct 17, 2012 | 05:53 PM
WalterM817's Avatar
WalterM817
I think someone posted about this type of problem after trailering a few weeks ago. It was lifter related. Something about the lifters losing their oil from bouncing down t,he road with spring pressure on them and with no oil pressure to keep them pumped up. Maybe try a search for trailering and ticking sounds here.
Old Oct 17, 2012 | 07:32 PM
pjones1969's Avatar
pjones1969
I had a ticking sound 2 weeks ago, was driving me nuts, I finally spotted it, the finned head bolt bridge adapters that bolt to the headbolt were loose, look at part no 43895-00 for pic
Old Oct 19, 2012 | 04:20 PM
cjbmustang's Avatar
cjbmustang
Thanks for the responses...the noise is gone. Took out both plugs and cranked the bike but nothing blew out. Started the bike again and it was quieter then went away completely. Im guessing a stuck lifter
Old Oct 19, 2012 | 04:24 PM
mkguitar's Avatar
mkguitar
happy ending.
FYI; improvised stethoscope from a screwdriver or any solid hose...even a piece of pvc pipe, placed from the ear bone to the suspect areas
Old Oct 19, 2012 | 04:44 PM
fwb35's Avatar
fwb35
If a bike is in gear and on a trailer it will still move a little back and forth pushing on the engine, if the engine is moving a little it probably pushed the oil out of a lifter, mechanic told me that once.
Old Oct 24, 2012 | 09:28 AM
cjbmustang's Avatar
cjbmustang
I felt bad for him because we drove 1300 miles down to fl for biketoberfest. Its been quiet.all week. Think we should leave the bike in neutral on the way home?
Old Oct 24, 2012 | 09:36 AM
Guitardude's Avatar
Guitardude
If the bike is tied down well, no point in leaving it in gear, and it it's NOT,then having it in gear isn't gonna help when it moves around...
