My Starter Exploded.
Old Oct 24, 2012 | 07:57 PM
Street Glide McVinny's Avatar
Stage IV
Default My Starter Exploded.
I have a 2011 flhx 103 with less than 6500 miles on it.
Lately it has had issues starting. The starter sounded like it had issues that I don't want to go into. But after work today. I heard a loud bang when I started it. It sounded like a piston came through the jug and didn't start. The second attempt, it started right up and ran normally. I stopped a short distance later and inspected it. I found the housing for the starter cracked.
Anyone know what would cause this.
Old Oct 24, 2012 | 08:07 PM
Teardrop's Avatar
Teardrop
Something binding in the starter motor maybe?
Old Oct 24, 2012 | 08:10 PM
riteway's Avatar
riteway
DAYUM!!! That sucks...
Looks like you are still under warrenty....
Old Oct 25, 2012 | 11:12 PM
Stage IV
Default Update
Well... I did some investigating and suspect that my Thundermax tuner may need to be adjusted. I haven't looked yet, but I found a lot of posts about starter kickback caused by excessive timing in the 0-256 range. It appears that it should be adjusted to 1-2 degrees. I read that the factory start timing is set to 0. I don't know what it is set at right now, so I'll have to check it and adjust it before I take the bike in for the repair. Hopefully there is no additional damage and the dealer won't investigate it too far, but I suspect that they won't care as long as they're getting paid by warranty. We'll see.
Old Oct 25, 2012 | 11:23 PM
mikebaby's Avatar
mikebaby
Take your Thundermax out before you go into the Dealer.
mikebaby
95yj
EVO
14
Jun 13, 2012 06:34 AM
JT-FXDL
Sep 29, 2011 02:28 PM
jrdfatboy
Aug 10, 2010 10:39 PM
msdenice
Nov 5, 2007 05:24 PM
lawdogso
May 9, 2007 04:49 AM
