Tourpak turmoil
Old Nov 14, 2012 | 01:22 PM
  #31
Stang951's Avatar
Stang951
Installation was pretty easy. You have to heat the sealant around the lense. Then you use a woodne dowel supplied with the kit to press the lenses away from the tour pak and pry it out at the tabs (which are small). You then have to glue the led board in the housing. After i you verify that the lights work you reheat the sealant and press the lense back in place.
Here is a link to the instructions
Old Nov 15, 2012 | 01:12 PM
  #32
Stang951's Avatar
Stang951
Installed the premium hinges and latches last night. Both really simple. I used the technique with a dremel cutoff wheel and ground / cut the rivets instead of drilling them.
The only things left are wiring a ground into the lighting harness, install the speaker pods and wire the rear speakers.
Thanks for everyone's input the turmoil has been quelled!
dajogejr
Sep 15, 2016 05:32 AM
Mountainkowboy
EVO
13
Nov 28, 2012 10:05 PM
rlowride
Sep 17, 2010 07:04 AM
rlowride
Sep 5, 2010 07:27 PM
riteway
Mar 21, 2009 06:59 AM
