Oil Draining out of Tank??
Old Nov 17, 2012 | 08:18 AM
14U24ME's Avatar
14U24ME
Default Oil Draining out of Tank??
What causes the oil to drain out of tank (into crankcase) after the bike sits for 2 to 3 days? the bike is a 2008 twin cam with a Fueling Pump & Plate..
Old Nov 17, 2012 | 10:39 AM
Dionicio's Avatar
Dionicio
Probably due to the check valve in the oil pump.
AlaskaAviator's Avatar
AlaskaAviator
I think there is an oring between the cam plate and oil pump that my be leaking.
Old Nov 17, 2012 | 11:56 AM
R-Jay's Avatar
R-Jay
+1 for the ck valve.
Old Nov 17, 2012 | 01:43 PM
2black1s's Avatar
2black1s
I've heard of and have experienced this issue with Softails where the oil tank sits higher than the oil pump, but what oil tank are you referring to on a Touring Model?
The oil pan and oil level on a Touring bike sits at or below the oil pump so how can the oil drain from the pan to the crankcase?
Old Nov 17, 2012 | 02:34 PM
14U24ME's Avatar
14U24ME
It is a softail(sorry)..thought I would post here because there are way more visitors on the touring side
Old Nov 17, 2012 | 04:50 PM
gregmay's Avatar
gregmay
Put the hsrley plste and pump back in it, it will be fixed. Its the way the fueling pump is made that causes it
Old Nov 17, 2012 | 05:22 PM
TexasFatboy's Avatar
TexasFatboy
It’s a problem that sometimes plagues soft-tails.
My 04 Fatty did this from time to time. I’ve never experienced any damage from this issue.
As the above poster said, it’s basically a leaking check valve.
Just make sure you run it for a couple of minutes before checking the oil level for an accurate reading.
Dan Tibi
Engine Mechanical Topics
14
Feb 19, 2018 02:10 PM
Trebor_HD
General Topics/Tech Tips
Sep 9, 2015 04:05 PM
billytwobags
Exhaust System Topics
Oct 30, 2013 03:25 PM
2006ultra
Oct 20, 2011 02:41 PM
pallet 0
Oct 15, 2010 01:51 PM
