I dont know how fork oil can have an affect on tire wear,well unless the tubes are not filled the same?
But since you did buy the bike used,there's a possibility the PO did something to the forks.
Might be a good idea to change the fork oil anyway.
Also check the wheel bearings,axle torque and tire pressure.
If you have spoked wheels,check the spokes for tightness,wheel runout and tire balance.
I dont know how fork oil can have an affect on tire wear.
All of the above sound a LOT more likely to me than the fork oil thing, but hey, it's an HD, so never say never.
Old/dirty fork oil isn't likely the cause of worn tread...worn bearings, tire pressure, imbalance are more likely a culprit, but you'd definitely have front-end vibrations. Try another shop (2nd/3rd opinion) and see if the majority rules w/these assessments.
2006 Road King Classic. About 18000 miles. I'm the second owner so I'm assuming its never been changed. When SHOULD it be changed?
Used bike.......change ALL fluids! Including fork oil & brake fluid. That way you know what you have & that all fluids are correct.
That being said, it's highly unlikely that fork oil is causing tire wear. Particularly without ride problems. "A little uneven" probably means cupping. Check inflation pressure & balance. Learn about the wear bars built into the tires & spend a dollar on a simple pocket ruler that measures in 32nd's of an inch. Measure your own tire wear & you'll know when to replace a tire so you won't be at the mercy (or lack of) a stealership.
Old oil can decrease damping and allow the wheel/tire to "bounce" more. A bouncing tire will wear "funny". The Harley damper rod system doesn't control damping/rebound very well to begin with and light wore out oil doesn't help. Heavier new oil isn't a bad idea. That said; bearing, balance and/or air pressure problems are more common/likely.
