Drive pulley change question??
Old Nov 18, 2012 | 10:09 AM
2012 Tequila SG's Avatar
2012 Tequila SG
Default Drive pulley change question??
Back in the day when we changed the front sprocket of the crotchrockets they would come out of the hole quicker. Will this also work on my 2012 SG ? If I were to go down in tooth count will it react the same way as the old bikes did?? Looking for some more out of the hole quickness with out cams just yet. Not concerned with top speed being slower as this is not a crotchrocket. Any help or advise would be greatly appreciated!
Old Nov 18, 2012 | 10:30 AM
sgdiesel's Avatar
sgdiesel
Reducing teeth on rear will give you exactly what you are asking
Old Nov 18, 2012 | 10:31 AM
DTTJGlide's Avatar
DTTJGlide
You can go down to a 31 pulley in front & it will help a little, any more than that & you need to change belts, can't just take out a link as with a chain.
Old Nov 18, 2012 | 10:34 AM
DTTJGlide's Avatar
DTTJGlide
This would do the opposite, plus you can't change the rear pulley on 09 & later with the IDS.
Old Nov 18, 2012 | 10:35 AM
twistedcherokee's Avatar
twistedcherokee
Wrong direction, bigger (more teeth) on rear, smaller on front will gear it down.
Toby
Old Nov 18, 2012 | 12:00 PM
sgdiesel's Avatar
sgdiesel
Toby
Quite right, my bad - read the question properly.....
Old Nov 20, 2012 | 05:04 AM
mike5511's Avatar
mike5511
I changed the rear to a 68T pulley (bigger by two teeth) and have a 31 tooth to go on the front that I haven't installed yet. I used the same belt. The rear wheel is slid up about 1/2 inch or so. When I install the 31T, the rear wheel will go back to the factory position. Hope to complete this this winter.
Old Nov 20, 2012 | 06:28 AM
grbrown's Avatar
grbrown
Cool
Will it work? Yes and a good way of waking things up. Unfortunately your choices are limited, due to Harley's design. Best place is the crankshaft compensator, but I don't know of any alternative sizes (there are several for TC88s and earlier), which leaves us with the rear belt drive.
Your stock trans pulley is 32T, but alternatives available are 31T and 30T. Frankly changing one tooth is not worth the effort and expense, so a 30T would be my choice. Moving to the rear wheel, the 68T pulley that Mike mentions combined with the 30T will give a decent improvement in overall gearing.
Going from stock 32/66 to 30/68 gives a reduction in gearing of almost 10% and an increase in rear wheel torque of the same amount. Makes for a cheap performance upgrade! From previous threads I understand your current belt will fit, but that is worth checking.
Old Nov 20, 2012 | 07:10 AM
btsom's Avatar
btsom
This might also be the place to discus getting the speedometer back somewhere close to being accurate and what happens to the 6th gear light if that might be a concern. All I know is that changing this stuff will throw the speedo off, don't know what to do about it.
Old Nov 20, 2012 | 09:26 AM
Hogpro's Avatar
Hogpro
Former Sponsor
I'd skip that stuff and throw some cams in it.
