Front suspension input
Old Dec 1, 2012 | 09:41 AM
fabrik8r's Avatar
fabrik8r
Originally Posted by troop
Your combo was initially what I was leaning towards. What do you consider "needing help"? So much debate between straight wound/progressive wound springs and how straight is better for the track but progressive better on the roads with cruisers/touring bikes. I wonder how stiff the stock H-D straight wound springs are ??
There's no debate from anyone who has tried both. HD stock springs are progessively wound or multi rate, the "stiffness depends on the year, 09 up were about 1/3 stiffer.
Old Dec 1, 2012 | 10:40 AM
troop's Avatar
troop
Oh, ok. Thought I read a tech article stating H-D used straight wound springs? Guess my 09 has 1/3 stiffer progressive wound springs. I do see the majority here does use straight wound so that should tell me something. Looks like majority consensus is either Race Tech springs w/intiminaters or Progressive monotubes. I have some time to decide....
Old Jan 5, 2013 | 12:23 PM
Red-line's Avatar
Red-line
Troop,
I'm considering the exact two options.
Have you come to a decision? And if so, what?
Cheers,
Old Jan 5, 2013 | 05:17 PM
troop's Avatar
troop
Originally Posted by Red-line
Troop,
Cheers,
No decision yet but leaning more toward the monotubes. It appears early quality control issues have been corrected ....
Old Jan 5, 2013 | 05:33 PM
porkchopsd's Avatar
porkchopsd
I did the HD front suspension upgrade with #3 #3 ohlins outback and the ride is outstanding. I can feel the feedback from the front end in a good way, twisties are funner. I've ridden about 10k with the setup.
Old Jan 5, 2013 | 06:18 PM
U-234's Avatar
U-234
Just got back from a test ride to try out my 90lb Race Tech springs with emulators valves. Big improvement.
Old Jan 5, 2013 | 06:28 PM
Juan L's Avatar
Juan L
Moderator
I went with the RaceTech 1.0 springs, fabrik8r modded Intiminators and Amsoil 5 wt fork oil. Prior to the swap my RKC was a nose diving, corner waffling pig but now rides and tracks straight in the corners. There is greatly reduced suspension dive and it soaks up bumps easily where clanging and banging before.
Old Jan 5, 2013 | 09:44 PM
troop's Avatar
troop
See ? Lotta tough choices to make!
Old Jan 5, 2013 | 09:47 PM
Juan L's Avatar
Juan L
Moderator
Nah...just go with what has been proven to work
Old Jan 6, 2013 | 06:52 AM
troop's Avatar
troop
Yup.. But what is that? Going thru the threads I see about a 50/50 ratio of RT-emulator-intiminator/monotube users and monotubes are starting to run away.......
