Cruise Control Cable Lash Initialization
Old Feb 3, 2007 | 03:31 AM
Harleypingman's Avatar
Harleypingman
Default RE: Cruise Control Cable Lash Initialization
Congratulations. I know I have been down that road of doing it the "right" way and the damn thing wouldn't cooperate and work the way it was supposed to.
Tell us how you got it to work.
Old Feb 5, 2007 | 11:23 AM
rkc9999's Avatar
rkc9999
That's the thing, I didn't do anything special, I just put everything back together and it worked. But the lash initialization wouldn't work as the directions said it would. Maybe it helped that I didn't adjust the cables at all.
Old Aug 14, 2013 | 06:14 AM
Trfisher's Avatar
Trfisher
6th Gear
Just installed 13" apes in my '07 Ultra. The tech manual states that the Lash is required if cables are replaced. I went thru the Initialization as required and my light NEVER turned green. However, the cruise does engage most of the time, but sometimes doesn't hold. It's about to tick me off. I ride a lot and CC is a necessity. Any help would be greatly appreciated. Even text me at 806-663-0116.
Old Aug 14, 2013 | 08:43 AM
nchogfan's Avatar
nchogfan
Correct me if I'm wrong but the manual for my '07 Ultra says that the lash initialization is only needed if the cable to the cruise module itself is replaced, and not the cables to the grip. We put new throttle cables on when we put the apes on it and had no problem with the cruise control. Just adjusted the proper slack out of the cables and away we went. CC works great!!
Old Aug 21, 2013 | 03:41 AM
Trfisher's Avatar
Trfisher
6th Gear
My issue ended up being a faulty "Roll Off" switch on the new throttle cable. The Roll Off switch is useless to me anyway, so I unplugged it and all is well.
jaxdwg
Sep 11, 2015 08:54 AM
ORradtech
Electrical/Lighting/Alarm
May 30, 2015 01:56 PM
JC650
Jun 23, 2011 06:39 PM
Geoff of NV
Mar 22, 2010 06:16 AM
voodoodrug
Dec 16, 2006 09:12 PM
