Poly bushings with 10" yaffe apes????
Old Dec 2, 2012 | 03:24 PM
maryvillept's Avatar
maryvillept
Default Poly bushings with 10" yaffe apes????
For those that have put on 10" yaffe Mbb apes did you change to poly bushings or not? I will be extending clutch cable to +4. Have abs brakes but most say brakeline will have enough length. Anything else I will need for the install?
Old Dec 2, 2012 | 03:55 PM
dawg's Avatar
dawg
It's always good to put poly bushings on when changing the bars. They outlast the rubber OE ones.
Old Dec 2, 2012 | 05:13 PM
steelerdude1's Avatar
steelerdude1
They are inexpensive, and they are easy to install. I replaced mine when I did my bars. I didn't notice anything different with them in there, but I did it while it was all apart.
Brake line is tight, but it works.
Old Dec 2, 2012 | 05:23 PM
chinookman's Avatar
chinookman
I didn't do the monkey bars. I did the yaffee classic 10" apes. Everything worked just fine except the brake line. Well I guess it works but it is really tight. It needs to be about a 1/2 inch longer. I changed to ploy bushings. Like everyone said cheap, easy to install, and will last longer than originals.
Old Dec 2, 2012 | 06:06 PM
PDDGM's Avatar
PDDGM
I am going with classic 10 in. Did you have to replace any cables, where do you get the bushings?
Joe
Old Dec 2, 2012 | 06:12 PM
steelerdude1
Joe
I have the Paul Yaffee Original bagger apes (not monkey bagger bars) I was able to use all stack cables, but I had to reroute the clutch cable to not run inside the fairing. Brake line is tight but works.
Old Dec 2, 2012 | 06:13 PM
dawg's Avatar
dawg
Bushings can be had at HD or aftermarket, your choice.
Old Dec 2, 2012 | 06:20 PM
HDJIM1158's Avatar
HDJIM1158
Do you have the HD part number for 2012 Ultra ?? Thanks in advance JIM
Old Dec 2, 2012 | 06:23 PM
dawg's Avatar
dawg
Old Dec 3, 2012 | 08:45 AM
HDJIM1158's Avatar
HDJIM1158
As always, Thank you
Be safe JIM
