Remap after Jackpot Header install??
Old Dec 12, 2012 | 12:43 PM
CGP93's Avatar
CGP93
From: Orig Surfers Paradise Australia, then Riyadh Saudi Arabia, Tokyo, Toronto, now So Cal
Default Remap after Jackpot Header install??
Looking to install Jackpot headers (2-1-2) on 09 SG. Have stage 1 AC and V&H Monster Ovals with HD ecm remap currently (with stock headers incl CAT). Bike runs great. But will I need to remap / install PCV etc, after new headers are installed?
thanks for advice in advance.
Old Dec 12, 2012 | 12:56 PM
Fast Aire's Avatar
Fast Aire
Former Sponsor
Youre going from a stock CAT system to a non CAT system with different mufflers so the flow will be different and could affect the over all performance. It is generally recommended that when ever a change is made to a motors performance design, a correct re-tuning should be done.
I have always been a supporter of getting a tuneable EFI vs a ECM flash. Yes it does cost more up front but in the long run, may be cheaper.
Old Dec 12, 2012 | 01:00 PM
pontiac69's Avatar
pontiac69
This is a very highly discussed topic and i would say 50% say yes to a tuner of some kind and others will say no tuner for a simple stage 1 (exhaust/ac). If you want some more performance then yes a tuner but if your just looking to have a little more sound and open the ac up a little then no. You say you have an hd ecm remap. Are you saying you have the stage 1 download? If yes then by opening up the exhaust and ac you have now brought it back to the stock lean condition which wont hurt anything.
Old Dec 12, 2012 | 01:20 PM
CGP93's Avatar
CGP93
Thank guys, I do have the HD stage 1 download done by LA HD. I just want a bit more exhaust noise as i find with the CAT its too quiet. Performance is fine currently (for me!) so if i put the JP Headers on you're saying that my current stage 1 download will be ok? no need to remap straight away?
thanks for fast replies guys!
Old Dec 12, 2012 | 01:37 PM
Jswerve's Avatar
Jswerve
Did you go through Fuelmoto? If so just call em up they will answer all your questions and hook you up with a new map if necessary.
Old Dec 12, 2012 | 01:40 PM
CGP93's Avatar
CGP93
Thanks Jswerve I will do that directly!
Old Dec 12, 2012 | 01:46 PM
Krulls09Ultra's Avatar
Krulls09Ultra
I Don't know if I missed something while reading this, but the 09's
didnt have a cat. So i would think that it would not have to be remapped.
I may be wrong and have been known to be wrong many, many times!
Old Dec 12, 2012 | 01:51 PM
Jswerve's Avatar
Jswerve
The California 09's did maybe he has one of those?
Old Dec 12, 2012 | 01:57 PM
Krulls09Ultra
You are correct, did not check out his location before replying.
Old Dec 12, 2012 | 02:01 PM
Jswerve's Avatar
Jswerve
