Are Mufflers Supposed to be Even?
Old Dec 24, 2012 | 11:12 AM
ZenGlide's Avatar
ZenGlide
Default Are Mufflers Supposed to be Even?
I just installed CVO SE take-off mufflers on my Ultra and the left side seems to stick out about 1" longer than the right side. I'm sure the muffler is on the cross-over all the way and don't want to put anymore pressure on it. I seem to remember noticing my stock mufflers were a bit uneven, but never paid much attention to it.
Is it normal for one side to protrude out further than the other side?
Thanks
Old Dec 24, 2012 | 11:16 AM
piesik650's Avatar
piesik650
my bike has same issue right now. and with a day at home I plan on trying to remedy it today somehow. it drives me nuts
Old Dec 24, 2012 | 11:20 AM
mkguitar's Avatar
mkguitar
they should be even, easiest if the bike is upright to see the difference
1 check that the header didn't get tweaked when you wrenched off the old mufflers
2. do not measure using the saddlebag guards for reference, they can be uneven, check from the wheel axle.
3. you can pull the right side back, as long as you have a good seal there ( new Torca clamps? they deform with use)
4 have someone help you spot that the mufflers hang down symetrically before tightening the clamps
and the mufflers are on the correct sides ? usually there is a depression on the rt side muffler for clearance
mike
Old Dec 24, 2012 | 11:22 AM
ZenGlide's Avatar
ZenGlide
When I took off the stock mufflers, I noticed the rubber mounted bracket on the left side was not as evenly spaced in the rubber mount as the right side. This leads me to believe the stock mufflers were a bit offset too. Not sure how to correct it.
Old Dec 24, 2012 | 11:26 AM
ZenGlide's Avatar
ZenGlide
mike
Thanks for the tips. I'm visually sighting it against my rear bumper. I'll level the bike and use a tape measure.
Old Dec 24, 2012 | 11:28 AM
Pumba11's Avatar
Pumba11
I have had issues where that slit in the intake end of the muffler (the slots that allow you to tighten it snug) will have a burr on it that hangs up on the header pipe no allowing it to get completely on. I have had to pull them off and and using a rounded file remove the burr and smooth it out. Slid on fine after that.
Old Dec 24, 2012 | 11:50 AM
Lowcountry Joe's Avatar
Lowcountry Joe
They should be very close to even. An inch is way too much. Things to check:
-Check to see that the cross-under pipe is totally seated in the header. It's easy not to get this joint totally seated.
-Check the bracket holding the cross-under pipe to the transmission. Make sure that the cross-under pipe is fitting snugly and properly in that bracket and that the bracket bolt is tight...don't over tighten that bolt though.
-Use silver anti-seize (available from the auto parts stores) on the outside of the header where the pipes slip on and also on the inside of the muffs where they slide on. The anti-seize will act somewhat as a lubricant to help you slip them on all the way and later, make it easier when you remove the mufflers down the road.
This with what has been suggested so far should help you find the issue.
Old Dec 24, 2012 | 12:08 PM
jjnoble's Avatar
jjnoble
mine are even.
Old Dec 24, 2012 | 12:11 PM
ZenGlide's Avatar
ZenGlide
My problem may have been that I didn't loosen or remove the crossover. I was following the manual and just removed the the 2 support bolts and loosened the clamp to pull the muffler. Maybe I did pull the crossover out of alignment when I was pulling the left side muffler. Wish I had thought about the anti-seize before I got everything back together. Thanks for your tips.
Old Dec 24, 2012 | 12:16 PM
ZenGlide's Avatar
ZenGlide
Ok... I leveled the bike on the jack and measured from the axle. Looks like there's slightly more that a .5" difference. The more I look at it, the less it bothers me. I may try to loosen the right side an pull it out a bit. If nothing else, I'll just remove the bumper since that's it main reference for the offset.
Thanks to everyone for the help.
