warm up process
Old Jan 17, 2013 | 12:54 PM
  #51
Def Mute's Avatar
Def Mute
After reading through all the responses...
Only two people, that I saw, may have checked their manual. Yes, the manual indeed does have a description of the warm up procedure in it.
Besides considering lubrication, you may be surprised, but different parts may take more or less time to warm up. Some parts are forged, some are cast. Forged parts take more time to warm up than cast parts do.
And, as stated previously by another responder, carb'd bikes have a slightly different warm up procedure than EFI.
Aside from that, you should also take into consideration that we are talking about an internal combustion engine, which can and will cause the cylinder walls to glaze over if left at idle for long periods of time. I'm quite sure that no one here can 'feel' that, or tell in any manner other than when the smoke starts to puff, when it is time to check the internals...
Old Jan 17, 2013 | 01:10 PM
  #52
RANGER73's Avatar
RANGER73
Originally Posted by dickey
Also, if you drain all the oil, the engine will have less internal resistance & more HP & torque.
And warm up alot faster.
Old Jan 17, 2013 | 01:57 PM
  #53
SkipCarey's Avatar
SkipCarey
And, as stated previously by another respiuionder, carb'd bikes have a slightly different warm up procedure than EFI.
I get tickled when i tell a guy to read his manual some of the replies are comical
Then i tell him yea your right wut does HD know..... they only been buildin scooters a 110 years break it in the that way and ride it that way as Im walkin off shakin my head .after all harley is just makin a suggestion and they put that in there to ruin your fun lol
Old Jan 17, 2013 | 02:03 PM
  #54
toothmansteveb's Avatar
toothmansteveb
Start motor, let idle for long enough to put on gloves/glasses pull in the clutch lever a few times and go.
Old Jan 17, 2013 | 02:08 PM
  #55
SkipCarey's Avatar
SkipCarey
The ones that get me are the guys that start one cold and immediately hit the rev limiter showin off nows thats entertainment
Old Jan 17, 2013 | 02:46 PM
  #56
Pumba11's Avatar
Pumba11
+1 for me. It's not foreplay.
Old Jan 17, 2013 | 03:19 PM
  #57
SanJuanRon's Avatar
SanJuanRon
My '05 Heritage demands at least 30 seconds of warm up or she "clunks" when I shift into first. SJ Ron
Old Jan 17, 2013 | 03:51 PM
  #58
larry bart's Avatar
larry bart
Originally Posted by SkipCarey
I kinda cringe an shake my head when i see some dummy hop on his scooter fire it up dump it in gear and take off haulin *** .....its his money but i respect the equipment more than your average joe cuz im a machinist/mechanic .I work in the nuclear power industry the emergency generators on the reactor coolant pumps are required to go from zero to full bore in less than 30 sec and they have heaters that keep the oil hot and we still lose one from time to time.
Work in the NUCLEAR POWER INDUSTRY and LOSE THINGS FROM TIME TO TIME
Old Jan 17, 2013 | 04:48 PM
  #59
patriot2500's Avatar
patriot2500
I start mine up before gearing up, which is a few minutes, than get on and go.
Old Jan 17, 2013 | 04:58 PM
  #60
zion's Avatar
zion
For both EFI and Carbed engines, H-D owner's manuals state:
The engine should be allowed to run slowly for 15-30 seconds. This will allow the engine to warm up and let oil reach all surfaces needing lubrication. Failure to comply can result in engine damage. (00563b)
Direct from the H-D manual for a carbed engine:
Cool Engine
Outside Temperature Cooler Than 60° F (16° C)
Turn the fuel valve to the ON position.
BE SURE THROTTLE IS CLOSED.
Pull enrichener **** to full-out position.
Turn the ignition/headlamp key switch ON and press starter switch to operate the electric starter.
Raise jiffy stand.
After initial 15-30 second warm-up, ride for 3 minutes or 2 miles (3.2 kilometers) with enrichener **** in full-out position.
After 3 minutes or 2 miles (3.2 kilometers), push the enrichener **** in to the 1/2 way position. Ride 2 minutes or 2 miles (3.2 kilometers).
After 2 minutes or 2 miles (3.2 kilometers), push the enrichener **** fully-in.
NOTE:
If outside temperature is cooler than 20° F (7° C) it may be necessary to roll the throttle 2 or 3 times.
Outside Temperature Warmer Than 60° F (16° C)
Turn the ignition/headlamp key switch on and press starter switch to operate the electric starter.
Raise jiffy stand.
After initial 15-30 second warm-up, ride for 1 minute or 1/2 mile (0.8 kilometer) with enrichener **** in full-out position.
After 1 minute or 1/2 mile (0.8 kilometer), push the enrichener **** in to the 1/2 way position. Ride 1 minute or a 1/2 mile (0.8 kilometer).
After 1 minute or 1/2 mile (0.8 kilometer), push the enrichener **** fully-in.
By comparison, here is all the owner's manual says for an EFI engine.
Press the starter button to start the motorcycle.
When the engine has started, you can operate your motorcycle as you normally would after raising the jiffy stand.
YMMV
