No throttle after Mini Apes
Old Jan 25, 2013 | 04:51 PM
davey019's Avatar
davey019
Default No throttle after Mini Apes
Uggh, got my WO578's on with my new painted inner fairing and all ready to start it up and the darn throttle doesn't work. Electrical issues here we go.
Old Jan 25, 2013 | 05:39 PM
C.H.L.'s Avatar
C.H.L.
You have throttle by wire, fly by wire, or whatever the new crap is called??
Old Jan 25, 2013 | 06:44 PM
Hotrodz_n_Harleyz's Avatar
Hotrodz_n_Harleyz
i would assume that's the case, as no throttle is pretty straight forward if it's cable powered... Myself, i know there's newer and more better and all that, but i like my old 2000 RK with the old fasioned throttle cables and stuff.
Old Jan 25, 2013 | 06:47 PM
davey019's Avatar
davey019
Yes I have a 2012 SG. I think they call it throttle by wire
Old Jan 25, 2013 | 07:22 PM
Jswerve's Avatar
Jswerve
Did you install it yourself? Sounds like either the grip isn't pushed on all the way or the wiring isn't correct...
Old Jan 25, 2013 | 07:35 PM
davey019's Avatar
davey019
Yes we did put them on and pulled the wires through. All lights, blinkers, everything, but the throttle. So we checked the connector and its all tight. The grip I believe is pushed on all the way. They are only 10 inch bars so we did not have to cut any wires or anything
Old Jan 25, 2013 | 08:09 PM
C.H.L.'s Avatar
C.H.L.
Yeah, could be grip. Pull the grip off, and just twist the TBW gear....
Old Jan 25, 2013 | 08:20 PM
5TIME's Avatar
5TIME
I want to hear the resolution. I have 578s in the box ready to install.
davey019's Avatar
davey019
Alright. I will check the grip tmrw. I just don't know of any wrong way to put this on. Thanks for the replies
Old Jan 25, 2013 | 08:33 PM
Jswerve's Avatar
Jswerve
Try to work the throttle with the grip off as the other mentioned...
