Need help with my 2003 ultra classic
Old Feb 19, 2013 | 10:13 PM
1plumr1's Avatar
1plumr1
same bike, same symptoms, third stator. I am also at 120K miles.
Old Feb 20, 2013 | 01:05 AM
BikerPaul's Avatar
BikerPaul
Last year I had similar problems. It was found to be a battery connection--the terminal bolt had loosened up and welded itself in the loose position. You might try loosening the terminals and the tightening them back up.
Old Feb 20, 2013 | 05:42 AM
Assegai's Avatar
Assegai
The stator is just a conductor rotating in a magnetic field. It's either working or not IMO. The rectifyer/regulator is electronic, I'd also think that it would die hard. What does that leave? Just connections (plugs-ins, cables, battery ground).
Old Feb 20, 2013 | 10:00 PM
robo5555's Avatar
robo5555
4th Gear
Originally Posted by grbrown
If you can measure across the battery terminals while the bike's voltmeter is reading zero, that will be a great help. If the hand meter tells you 14.5 volts, then there is an electrical fault in the wiring to the bike's meter. That may also be a loose connection or trapped wire, as it sometime reads fine.
With the voltmeter reading zero the bike reads the same...12.5 across and 14.3 with engine running.
Old Feb 20, 2013 | 10:04 PM
robo5555's Avatar
robo5555
4th Gear
Where does the voltmeter wire go to?
GEORGEW
Aug 10, 2016 09:06 PM
MASA
May 8, 2016 10:59 AM
ClintVRSCDX
VRSC Models
13
Jun 22, 2014 07:39 PM
Lawdawg
Feb 5, 2013 05:28 PM
joebotics
Nov 28, 2011 05:55 PM
