Shocks PSI 12 SG
Old Mar 16, 2013 | 06:14 AM
tacoma5432's Avatar
tacoma5432
Default Shocks PSI 12 SG
What are all of you running in your stock shocks? I am 300 lbs and my old lady is 130 lbs... I know the stock shock suck and I need to suck it up and replace them but id like to hear what you all run. Thanks
Old Mar 16, 2013 | 07:37 AM
grbrown's Avatar
grbrown
This is a common subject and was recently discussed here. Air pressure has been a debating topic since the 80s when Harley first installed their air shocks. I don't think I have ever seen a consensus, so be prepared to experiment! Or chuck them in the bin and get some decent ones! If you put 'shocks' into 'Search' you will never be able to read all the results......
Old Mar 16, 2013 | 07:53 AM
NECaveman's Avatar
NECaveman
I would pump mine up to 15-20psi solo and 25 or slightly higher two up. The issue I had was if I could get the solo/two ride set right for today, it would not be the same tomorrow and I repeated the air in/air out process daily. The ride was not always acceptable. I replaced the air shocks with the HD premium adjustable shocks and they are better ride solo/two up.
Old Mar 16, 2013 | 07:54 AM
89FLHT's Avatar
89FLHT
on my 11 SG they provide a reccommended guide in the owners manual. I run 26 to 28 when I'm solo. And 40 2 up. I'm 225 with about 10 lbs of stuff in the bags most of the time. The ride feels good and does not bottom out too easily.
Old Mar 16, 2013 | 07:55 AM
wintersucks's Avatar
wintersucks
I have almost identical payload here and I run 38-40 psi....... not the ride I expected for 20K either. Still in limbo over which replacement shocks to go with.
Old Mar 16, 2013 | 08:01 AM
tacoma5432's Avatar
tacoma5432
Ive been keeping it around 40 psi for 2 up. as for the aftermarket shock every one has opinions, i guess im just gonna have to buy something and if they suck i will be out the cash. But you are absolutely correct on it not being the ride expected for over $20,000. The seat change helped a little.
Old Mar 17, 2013 | 11:56 AM
John Scott Jr's Avatar
John Scott Jr
6th Gear
2 up with over 400 lbs, you should run 40-50 lbs to keep from bottoming out.
Old Mar 17, 2013 | 12:02 PM
useR 564357348's Avatar
useR 564357348
I'm 215 and solo run 30. 2 up and gear I'll go to 50.
Old Mar 17, 2013 | 02:01 PM
hynsonx's Avatar
hynsonx
Im 295 and the old lady is 119 i keep mine at 50 two up and about 40 just me .We rode to nashville and back it work out well.
jacksons1998
Aug 20, 2017 04:23 PM
HDJOE60
2014-2024 Touring Models
15
Apr 26, 2015 01:05 PM
HDJOE60
Nov 5, 2014 08:41 PM
B4Wheeler
Sep 16, 2013 07:57 AM
davidw221
Sep 18, 2007 08:18 PM
