mp3 and auxillary plug - question
Old Feb 13, 2007 | 10:55 PM
twinfreeze's Avatar
twinfreeze
Default mp3 and auxillary plug - question
tried to hook up my mp3 on my 05 ultra today. Plugged the cable into the aux port, turned on the aux switch and nothing. Checked mysystem (ACC on,volume, mp3 player onetc.) and still nothing. Any thoughts or ideas? Thanks.
ride safe and stay warm
twinfreeze
Old Feb 13, 2007 | 11:05 PM
todd6751's Avatar
todd6751
Default RE: mp3 and auxillary plug - question
i was going to get an mp3 this weekend. i'll try it out and let you know if i have trouble.
Old Feb 14, 2007 | 12:07 AM
choochoo's Avatar
choochoo
I got an older rca mp3 player maybe four years old.
Noticed that even whenI plug the power wire into the cig outlet
if batteries in the mp3 are dead it won't play.
Here's how I hook mine up.
take a audio patch cord and plug it into the head phone jack of the mp3.
the other end into the auxillary input jack on front of radio.
Turn ignition on select auxillary, turn on mp3 and turn up volume on the mp3 (this is a must Imax volume the mp3) then adjust listening volume on the radio.
If this don't work you got a bad mp3 (try headphones) or bad radio.
But I bet maxing volume on mp3 will fix it.
Old Feb 14, 2007 | 12:24 AM
twinfreeze's Avatar
twinfreeze
thanks for the info!
twinfreeze
Drifting Texas's Avatar
Drifting Texas
ORIGINAL: twinfreeze
Are you sure you have a good cable?
Another thought is make sure you have the volume on the MP3 player turned up.
Old Feb 14, 2007 | 01:43 AM
SteveO's Avatar
SteveO
Mine works fine on the aux on my 05 Ultra, has lower volume, but works. Make sure you have the correct plug.
SteveO
Old Feb 14, 2007 | 01:45 AM
SteveO's Avatar
SteveO
Mine works fine on my 05 Ultra in the aux plug. However it does have a lower volume level, have crank up the radio volume almost all the wayto get the sound.
SteveO
Old Feb 14, 2007 | 02:12 AM
twinfreeze's Avatar
twinfreeze
thanks again guys. I'll give it a try.
twinfreeze
my67pnycar
Nov 3, 2010 01:13 PM
badwiser
Jan 30, 2010 07:55 AM
eagle212a
Apr 14, 2009 11:36 AM
profinish
Feb 21, 2008 09:01 PM
VROCK SE
May 16, 2006 11:06 PM
