Replacing 99 Fork legs with a 2000+
Old Apr 7, 2013 | 01:55 PM
Frogprince's Avatar
Frogprince
Default Replacing 99 Fork legs with a 2000+
I have tried searching for this and I haven't found out everything I need to know.
I am aware of the axle size changing in 2000 to 1". I was thinking of replacing the front end either to chrome or black on my 1999 FLHTCUI. I would like to get a newer style wheel or wheels on it.
The front end I was wondering if I swapped in the fork legs from a 2000+ and got a matching axle and rim would it work?
Old Apr 7, 2013 | 01:58 PM
DTTJGlide's Avatar
DTTJGlide
Yes, any 00-07 wheel & 1" axle or any 08-13 wheel & 25mm axle will work with the matching year spacers.
Old Aug 13, 2013 | 09:12 AM
BigFokker's Avatar
BigFokker
Hey Frogprince,
Did you end up making this swap? If so, how did it go?
My next task is to go with a black front end and a new front wheel, but I was up in the air about the fittment and sizes. I'm hoping an 00 and up set of forks will bolt up to my 99. After that, it should be pretty straight forward with wheel choices.
Old Aug 13, 2013 | 09:27 AM
fwb35's Avatar
fwb35
I to have a 99 Electra Glide, does this mod have to be done to put different rim on the front?
Old Aug 13, 2013 | 09:37 AM
grbrown's Avatar
grbrown
Wink
Only if you want a later wheel. Your bike has 3/4" tapered roller wheel bearings, from 2000 they use 1" ball races. There are other differences, such as the later bearings are larger in OD and your brake rotors won't swap over, however if you use a wheel with tapered roller bearings you will be fine.
AKIRA56
May 30, 2024 07:16 PM
cgtrigg
Apr 9, 2012 01:21 PM
JIMSFBL
Sep 3, 2011 10:52 PM
niteglide
Feb 8, 2010 12:05 PM
lewistg
Feb 6, 2008 06:57 AM
