Oil leak - right front side of crankcase
Old Apr 14, 2013 | 04:13 PM
semiret's Avatar
semiret
Thumbs up Oil leak - right front side of crankcase
I have an oil leak on my 2011 FLHP.
It is coming from a three wire connector on the front right side of the crankcase. This connector is below and to the right of the Crankshaft Position Sensor. It is very low on the crankcase and almost to where the crankcase and primary case meet
Although it seems highly unlikely to me, these three wires appear to come out of the crankcase.
One of the three wires go to the Jiffy Stand Sensor.
The other two appear to go to the Voltage Regulator
I tried taking some pictures, but none of them were very good. I hope the verbal description will be sufficient.
I have spent most of today scanning the service manual to no avail.
So, I have some questions:
- Do these wires REALLY come out of the crankcase, or is there a switch that these wires are connected to
- If there is a switch, what is it called
Hope this makes sense.
Steve
Old Apr 14, 2013 | 04:45 PM
Bill03E's Avatar
Bill03E
I think you are talking about the stator wires, the only real way to fix the leak is to replace the stator, but I have seen guys clean it real well with break clean , and then use a toothpick, and poke RTV silicone in there , let it set for a day, and it lasts for several thousand miles.
Oh to clear up confusion, that would be on the left side of the bike.
Old Apr 14, 2013 | 05:05 PM
1st 96 ultra's Avatar
1st 96 ultra
right side confused me to , left side stator , right side ?
Old Apr 14, 2013 | 05:08 PM
ZUTEDUFF's Avatar
ZUTEDUFF
if it's right side setting on the bike,,,,,probably oil pressure sending unit...
if it's right side off the bike looking at the bike from the front...,,,,stator--------
Old Apr 14, 2013 | 05:22 PM
semiret's Avatar
semiret
Sorry for the confusion. I've never known how to tell the left side from the right.
I think Bill03E has got it. I looked up the stator in the service manual and it sounds like that might be the problem.
To clarify (hopefully)
- It's on the front of the engine on the same side as the Jiffy Stand.
- The Crankshaft Position Sensor is also on the same side.
- The leak is coming from a connector or seal that is below and to the right (looking at the bike from the front) of the Crankshaft Position Sensor.
- It is very close to where the primary case attaches to the crankcase.
Thanks
Old Apr 14, 2013 | 11:10 PM
Bingee's Avatar
Bingee
That's the stator wire plug. I had the same leak. Fixed it with Ultra Black RTV. Do a search on stator in the forum for instructions on how to fix. Otherwise you will need to replace the stator.
Old Apr 15, 2013 | 09:20 AM
semiret's Avatar
semiret
Thanks. Once Bill03E told me what the leak was (in spite of me not knowing my left from right), I did some searching. Using the RTV seems like a good thing to try, as long as I can get things completely clean and dry.
However, this leads me to, hopefully not too dumb, question 1:
1) Is the leak engine oil or primary oil??
I changed the oil, all 3 holes, about 2000 miles ago. It was my first time. When the dealer had changed the oil in the past, the oil level barely reached over the 'add' line. I added a little bit more oil to reach half way between the 'add' and 'full' lines.
Dumb questions number 2:
2) Did I bring this on myself by overfilling the crankcase??
Thanks
Steve
Old Apr 15, 2013 | 10:20 AM
Bingee's Avatar
Bingee
Thanks
Steve
The oil is primary oil. It leaks past the rubber seals in the plug. The cause is bad design by the Moco. Nothing you did. Get some Ultra Black RTV and some spray brake cleaner with that skinny red squirt tube. The idea is to clean out all the oil just under the grommet and in the hole. Spray directly into it and all around so that when the RTV goes in, there's no oil and it seals the plug completely. Don't worry about the fluid going into the primary. It won't. Use a wet finger to smooth the RTV out and make it look smooth with some RTV holding the grommet to the case. Let it cure for at least 24 hours. It's very tough stuff when done.
Old Apr 15, 2013 | 10:52 AM
2black1s's Avatar
2black1s
Yep... Sounds like the stator grommet is leaking. Very common. The RTV is a good fix if done properly. I've done both of my bikes this way.
The attached thumbnails show photos of my repairs... Take note of the RTV between the grommet and the engine mounting flange ("A" Motor) and the engine case ("B" motor). I filled that space with RTV to provide some extra stability for the grommet.
And here's a couple links to discussions of this same topic...
https://www.hdforums.com/forum/touri...il-leak-3.html
https://www.hdforums.com/forum/touri...g-fixes-3.html
And for the left/right thing... Just remember that left and right are as you sit on or in the vehicle.
Attached Thumbnails Oil leak - right front side of crankcase-stator-grommet-003.jpg   Oil leak - right front side of crankcase-stator-grommet-007.jpg
Old Apr 15, 2013 | 11:23 AM
Delzore's Avatar
Delzore
the stator is covered under warranty..
if you are still under normal or extended, then take it in and they will actually put in a brand new stator for you...
Had same thing on my 09 Road King... 50 bucks for my extended warranty and they replaced it with a brand new unit.. was aroudn 30k miles at the time.
