Mice
Old Feb 19, 2007 | 02:34 PM
Sammi's Avatar
Sammi
Default RE: Mice
The little bastards used to build nests in my Triumph's air filters.
About 6 moth ***** in a nylon stocking did the trick.
Sammi
Old Feb 19, 2007 | 06:48 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
Default RE: Mice
Mouse Trap
Or Poison
Old Feb 19, 2007 | 08:26 PM
Crazy Biker's Avatar
Crazy Biker
Default RE: Mice
Poison D-CON.
Old Feb 21, 2007 | 07:47 AM
PapaTravis's Avatar
PapaTravis
Default RE: Mice
If you are worried about the pipes, read somewhere to stick copper wool (like steel wool) inside the pipe. Make sure to use copper though to prevent corrosion-Travis
Old Feb 21, 2007 | 09:32 AM
Point Man's Avatar
Point Man
Default RE: Mice
Dryer sheets: Put them all around the edges of the shed. Hell, I'm getting sick of the smell myself! Had mice get in the air box of my ATV too. Put the dryer sheets in there too. So far, so good; no mice. Might want to stuff a sheet or 2 under the seat or near the battery on the bike. On the ATV, mice chewed the battery cables down to the wire; built a nest in there! SOB's!
Old Feb 21, 2007 | 05:00 PM
wingt50dw's Avatar
wingt50dw
Default RE: Mice
D-CON!!! That will get their nasty little a$$eS!
Old Feb 22, 2007 | 11:57 AM
zadmat's Avatar
zadmat
Default RE: Mice
that is funny so many had the same problem with the mice getting into the airbox of there four wheelers, i had the same problem. i actually bought a metal mesh kitchen sink drain strainer and used a clamp and fixed it over the air intake tube and no more problems. It took some time but worth the effort. Those friggin critters
Prayinghands
Aug 20, 2018 08:09 AM
offbeatmammal
Jun 25, 2018 11:24 AM
MartinusDK
Jun 22, 2017 10:51 AM
Rubline
Aug 20, 2016 04:26 PM
Crashone
EVO
18
May 24, 2015 07:58 PM
