Carbon Question,pros or backyard
Old Apr 23, 2013 | 02:47 PM
nomad billy's Avatar
nomad billy
Default Carbon Question,pros or backyard
OK guys heres the thing,had a noise in the engine seemed like from lifters so replaced them,didnt work.Borrowed a bore scope and have a heavy carbon deposit on both piston and intake valve,not leaking(done a leakdown)but the tapping is nuts.Diagnosis leaking valve seal,ok but no time have to make a 1500 mile trip in 2 days.So ? anything I can do to get some of the carbon off quick?Worried about big chunks scoring something or bending something important. Any kind of help much appreciated,thanks.
Old Apr 23, 2013 | 02:52 PM
mkguitar's Avatar
mkguitar
well,
you can always try spraying water into a running motor.
with motor running and intake exposed have someone crank the throttle wide open and at the same time spray as much a fine mist of water into the intake as you can, while keeping the motor running.
that'll remove carbon.
cave man style
mike
Old Apr 23, 2013 | 03:52 PM
FLUltrarider's Avatar
FLUltrarider
What brand of gas you using and are you doing oil changes on time? I've never heard of that much carbon build up in a properly maintained motor. As to removing it, you can add techron to the tank per the recommendations and it'll remove it as you ride. Since your're doing a long ride it should help clear it pretty quick. Chevron, Shell, Mobil, and Sunoco are good gasolines to use that will help prevent the build-up.
LowriderHarold
EVO
Apr 9, 2019 04:19 AM
hardheaded
Shovelhead
185
Mar 17, 2018 10:04 PM
patflynn2
Jun 6, 2011 06:18 AM
VETERAN75
EVO
17
Aug 23, 2010 03:40 PM
lrntowrench
Feb 5, 2008 06:37 AM
