oil pressure gauge install
Old Feb 19, 2007 | 07:13 PM
ringonking's Avatar
ringonking
Default oil pressure gauge install
i was wondering if anyone out there can tell me if there is a special way of removing the oil pressure swtich from the motor? do i really need to take the front exhaust pipe off? and the floor board too? is there a special tool for this? any and all info will be greatly appreciated!!! thanks!!
Old Feb 19, 2007 | 08:03 PM
jeepster09's Avatar
jeepster09
Default RE: oil pressure gauge install
Depends on the bike...but I did mine with regular tools.
Old Feb 19, 2007 | 08:57 PM
rdking330's Avatar
rdking330
15/16 or 1 1/16 depending on what bike and oil press. switch, what are you doing putting a oil press. gauge? I have a 2005 road king had the long oil press. switch 1 1/16, I took off the oil filter housing to get to mine and just used a 1 1/16 wrench.
Old Feb 19, 2007 | 09:01 PM
rdking330's Avatar
rdking330
FYI I also had to use a 45 degree brass adaptor, got it at ace hardware to utilize the stock press. switch
Old Feb 19, 2007 | 09:13 PM
Ram's Avatar
Ram
I used standard tools / sockets. But did remove the oil filter housing as 'pvbjr' mentioned.
I didn't want brass and my sender was for the marine gauges and slightly larger then H-D style stock for Ultra or EG with oil psi gauge.
Went with annodized steal hydralic fittings upto 3000psi. I know its a bit much on the psi, but didn't want anything cracking from vibrations.
the thumbnail is one attachment, and the word attachment 2 is the second, weird how that worked out!!
[IMG]local://upfiles/4133/9A58AE5F754E4E45AA2C5769AA80CF69.jpg[/IMG]
Old Feb 19, 2007 | 09:15 PM
ringonking's Avatar
ringonking
pvbjr,yes im doing a pressure guage.sorry,i should have told you guys thathave a 2000 road king.i am in stalling a ness gauge kit.it comes with the adapter and all the fittings.so i need to take off the oil filter housing to do this?thamks for all the info guys!
Old Feb 19, 2007 | 09:30 PM
Ram's Avatar
Ram
ORIGINAL: ringonking
In my case it was necessary to attach the "T" fittings to the engine cases. I didn't have to worry about the pipes. Found that clearance was fine. Overall mine looks like a tight fit but actually I've got plenty of room for everything. Have had no problems at all.
Yours should be the same.
Old Feb 19, 2007 | 09:43 PM
ringonking's Avatar
ringonking
thanks ram! i think ill wait till it gets a little warmer before i do any more! LOL so do you think i can sneak in a socket in there without taking off the oil filter housing? thanks again guys!
olelucky
Milwaukee Eight (M8)
Nov 10, 2016 08:25 PM
BiggestDawg
Sep 27, 2012 08:00 AM
shovelhead716
Shovelhead
Aug 19, 2011 11:37 PM
michael95688
Sep 9, 2008 01:53 AM
rdking330
Jan 28, 2007 08:46 AM
