Adjust headlight without level ground
Old Apr 28, 2013 | 07:56 PM
2ropes's Avatar
2ropes
Default Adjust headlight without level ground
I installed a new Hella e-code light and figure I need to adjust my light now but don't have 25' of level ground. My garage is only about 20'deep and my drive starts to slope immediately once leaving the garage. Is there a way to compensate for this like maybe measuring the amount of drop from the wall to the rear of the bike and compensating the "aim" point up on the wall. Or maybe determing the angle the bike is sitting and prop a sheet of plywood up on the far wall at that same angle.
Maybe I'm over thinking this?
Old Apr 28, 2013 | 08:53 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
put a phillips in your pocket wait till dark and go take a ride.
Old Apr 28, 2013 | 08:59 PM
redrub's Avatar
redrub
Yes, you are over thinking this.
Get it close enough in your garage then follow bigdumbnoitall00's advice. A parking lot, a building, a screwdriver and a tape measure. You're golden.
Old Apr 28, 2013 | 09:01 PM
bigdumbnoitall00
don't even need a building,you'll know where it needs to go after a few miles on the road.
Old Apr 28, 2013 | 09:18 PM
K Melancon's Avatar
K Melancon
5 feet outside the garage make a mark. Shoot that angle into the garage and make a mark on the back wall. You now have your 25 feet you wanted. This will get you close.
I have a piece of masking tape on the back wall and on the side wall so that when ever I load it up or change air pressure I can check it. I like to have the beam slightly lower than recomended because when I get to speed it tends to rise slightly.
Old Apr 28, 2013 | 10:21 PM
rpking's Avatar
rpking
Hey OP how do you like that hella E code light?
Can you tell a big difference?
NDanecker
Aug 5, 2020 11:42 AM
bigpappa160
Sep 21, 2018 04:44 PM
Gasguzlr
2014-2024 Touring Models
Aug 8, 2014 04:22 PM
eberg
Mar 11, 2013 05:10 AM
JT-FXDL
Mar 27, 2010 03:38 PM
