How can I check the adjustment on my headlight without having 25' of level surface. My garage is only 20' deep and the drive starts to slope away at the garage entrance as well as the garage must slope too.
With my front axle at 25' my rear axle would be 6.5" below level and my front 5.5" below level. Say I set the rear tire on a board giving me about 1" more height it would justify the bike; could I then mark my alignment position on the wall 5.5" lower then the calculated height per the service manual and make necessary adjustments?
Take the ratio of distance to wall versus suggested distance, and apply that to the measured drop.
So if you're 20 feet away when the suggestion is 25 feet, that's 80%. So multiply the suggested drop in the beam height by 0.8. If you're 15 feet from the wall, multiply the suggested rop in beam height by 0.6
Additionally, acamj's suggestion to go diagonally is a solid one.
Can you backed your bike in the corner and aim the light at the other corner?
That won't get me much more distance. Big house and small garage, when we were looking at homes there were very few with large garages around here, at least in our price range! With my Dakota in the garage and the door closed you have about 2 1/2' to walk behind it. The only way you could get 2 cars inside my garage is if you had absolutely nothing else inside the garage; it's about 20' x 20". I'm done venting about my garage now, at least I have one!
YOU NEED TO TAKE INTO ACCOUNT THE REFRACTION OF LIGHT FOR CHANGING THE DISTANCE. HERE IS A SIMPLE FORMULA TO HELP:
Given a normalized light vector l (pointing from the light source toward the surface) and a normalized plane normal vector n, one can work out the normalized reflected and refracted rays: Note: must be positive. Otherwise, use
Thanks Gunner.... I'll get right on that!!!!!!!!!!!!!!!!
