Susoension noises
Old May 10, 2013 | 08:36 AM
Bullitt59's Avatar
Bullitt59
Default Susoension noises
I have a 2011 Ultra Classis with the HD Profile® Low Touring Shocks on the rear. I also have a lowering kit for the shocks which are set at position 1, which is the smallest adjustment on the kit. I usually run the shocks at 35-40 lbs of air. When riding, on a variety of bumps, and not all the time, the left side makes a clunking noise, like the shock is bad and the bike seems to bottom out. It happens when I am alone & also when my wife is on the back. I have checked all the fittings and they seem to be ok & the shocks are holding the air.
Any ideas?
Old May 10, 2013 | 12:29 PM
mkguitar's Avatar
mkguitar
I wonder if the shocks are topping out ?
I use the same shocks on my 09 FLHTC- solo at 235#( with gear), no tourpak...I run 7 to 10 pounds pressure.( no lowering kit)
otherwise check the surety of your lowering kit install and shake the bike...anything bouncing in the saddlebag? muffler or saddlebag mounts tight?
mike
legendzzz
Aug 31, 2019 10:58 AM
bzmannn
May 23, 2014 02:55 PM
SOLOLUCKY
Jun 30, 2009 02:44 PM
ozzyg
Oct 10, 2008 09:02 AM
HDrider@xplornet
May 7, 2008 03:25 PM
