soft UC brakes
Old Feb 21, 2007 | 01:34 PM
gman's Avatar
gman
Default soft UC brakes
I have a '06 WG that the front brake is pretty solid. when i bought my '07 UC I noticed that the front brake felt a bit mushy. Bled the brake, but no change. went to the dealer and tried the brakes on a bunch of new UC on the showroom. they are like mine, a bit mushy. the dynas and a new SE UC were solid on the feel.
one of the mechanics told me to use a putty knife and push the pads back a tad, and bleed again. no change.
Is this something common with the dual disc UCs? Will changing to braided lines versus the rubber lines help.
Brake works well, but a definate difference between my Dyna and the UC.
[IMG]local://upfiles/12616/50B8DCD0F5084C44BEC899AB9AA9404A.jpg[/IMG]
Old Feb 21, 2007 | 01:49 PM
GTK's Avatar
GTK
Default RE: soft UC brakes
I try the braided lines first.You will notice a firmer brake with these versus the stock lines.
Old Apr 5, 2010 | 06:56 PM
Jeeps Dirty's Avatar
Jeeps Dirty
I have a 2006 Street Glide with the dual disc brakes. They are also mushy. I have to pull all the way to the throttle to make her stop. Im working on bleeding the brakes better. Pads are good and it stops when you pull to the throttle but its terrible on a hill.
Old Apr 5, 2010 | 07:09 PM
dawg's Avatar
dawg
Originally Posted by Jeeps Dirty
I have a 2006 Street Glide with the dual disc brakes. They are so mushy. I have to pull all the way to the throttle to make her stop. Im working on bleeding the brakes better. Pads are good and it stops when you pull to the throttle but its terrible on a hill.
Have you tried cleaning the pistons?
Old Apr 5, 2010 | 11:24 PM
Jeeps Dirty
Hmm I have not cleaned the pistons yet. But I will. I just flushed the brake system and bleed them using those Speed Bleeders. Went through 32oz of brake fluid. Its bungied and sitting over night now. The brake lever still almost touches the throttle.
Old Apr 5, 2010 | 11:31 PM
emwolb's Avatar
emwolb
are the pads a bit on the skinny side? if so, then you could end up with a lot of lever travel before you have a good solid feel.
Old Apr 6, 2010 | 09:10 AM
Jeeps Dirty
No joy this morning either. Same thing, can pull the brake lever all the way to the throttle. They work I just have to pull them so far to get them to work. Pads look pretty good.
Old Apr 6, 2010 | 11:27 AM
grbrown's Avatar
grbrown
Doesn't sound right! Are the pucks free in the calipers? I have another brand bike where dust builds up and they eventually stick and cause a similar problem to yours.
Old Apr 6, 2010 | 03:22 PM
gman's Avatar
gman
i replaced the front line with a braided steel line, re-bled with no change.
again, every UC in the showroom is just like that - a bit mushy, compared to a single disc WG or a SE UC. Must be something with the calipers vs a single caliper or the SE Bremo calipers.
Old Apr 7, 2010 | 06:01 PM
Jeeps Dirty
Brought the bike to Harley yesterday and picked her back up today. They bleed the front brake system via vaccum pressure. Its not like the ol Softail but MUCH better. Have plenty of room now between the grip and the lever. I wish I could have found that mighty vac deal so I could have done it myself. Free of charge from Harley though. Love those guys.
LAFO
Apr 20, 2018 11:17 AM
fat_tony
May 12, 2010 01:27 AM
mcdurhamj
Apr 5, 2009 02:51 PM
SunRa73
Sep 27, 2008 10:46 PM
HB
Jan 13, 2008 11:34 AM
