Road glide AUX input volume very low
Old May 19, 2013 | 10:21 PM
jsl36's Avatar
jsl36
Default Road glide AUX input volume very low
2008 road glide when a phone is plugged into the aux input the volume that plays back through the bikes speakers is very quiet
solutions?
Old May 19, 2013 | 10:25 PM
UUNetBill's Avatar
UUNetBill
May be a stupid question, but have you checked the volume on the phone? My iPhone needs to be close to maxed if I want to be able to hear it...
Old May 19, 2013 | 10:30 PM
mkguitar's Avatar
mkguitar
boostaroo or other inline amplifier
mike
Old May 19, 2013 | 10:31 PM
jsl36's Avatar
jsl36
yep volume is all the way up.. tried it with an iphone 5 and a droid.. the iphone was louder but neither would be loud enough to hear with the bike running
Old May 21, 2013 | 04:32 PM
ucommbxny's Avatar
ucommbxny
Boostaroo headphone amp about $30 at your local radio shack. They run on 2 AA batteries. It will make a difference.
Old May 21, 2013 | 07:49 PM
Cosmic Charlie's Avatar
Cosmic Charlie
WHY ?
my ipod touch plays plenty loud
Boostaroo does work well - though I don't need one ...
I'd ask Iron Cross Audio ... you problem is not common or normal ...
Old May 21, 2013 | 08:05 PM
mkguitar's Avatar
mkguitar
Originally Posted by Cosmic Charlie
WHY ?
the line level output from some mp3 players xm receivers and other devices may be lower than the level of the fm/am/cd playback through the stereo system.
an inline amplifier on the input may help to balance those levels for best signal to noise ratio, fidelity, and so you don't blow your head off when switching inputs.
an apple device may give different levels whether using the headphone jack or the 30 pin connector ( or the new connectors on the iphone 5's)
also check whether an EQ setting is used- some EQ settings drastically affect the perceived volume
also check the cable used to connect- i use a macally with 4 conductor plug at the phone end- 3 at the radio end.
an inline button allows me to play/pause, ff, rew.
this all assumes that the mp3's are "recorded" at a level which is sufficient- it is possible to mess up settings when converting cds to mp3's.
mike
Old May 21, 2013 | 08:23 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Something is wrong with your audio input circuit on that radio. You can mask the issue with an amp, but your radio ain't right my friend.
Old May 21, 2013 | 08:31 PM
Cosmic Charlie
[quote= but your radio ain't right my friend.[
ditto
[url]http://www.ironcrossaudio.com/[/url]
Old May 21, 2013 | 08:34 PM
EasternSP's Avatar
EasternSP
Here is a test to see the difference between ipods and your phone. Plug your ear buds into the ipod and listen to some music. Note the volume level. Now plug that same ear bud into you phone and listen to a call. Note the volume is probably lower coming out of the phone.
Toofat
Mar 4, 2014 03:47 PM
Racey
General Topics/Tech Tips
Jun 27, 2009 01:53 AM
Ultrasweet
Aug 10, 2008 04:24 PM
usualsuspect
May 26, 2008 11:51 PM
GasCan
Aug 12, 2007 04:06 PM
