Good Vibrations?
Old May 24, 2013 | 08:00 AM
lionsm13's Avatar
lionsm13
Originally Posted by scotracy
Great as a song... bad on a bike. Sounds like a trip to the dealer...warranty issue, could be a number of things.
Check the obvious and then make the dealer fix it.
Shouldn't be a big deal?
Old May 24, 2013 | 08:12 AM
pontiac69's Avatar
pontiac69
Originally Posted by TMOUT
Really? First I ever heard of that. So if it's torqued too tight it causes vibration? This has got my interest since I changed my stock pipes to V&H Dresser Duals over the winter, and I've noticed a vibration during deceleration that wasn't there last season when I put it away. Wonder what the correct torque setting is for that mount?
I just installed the dresser duals a few days ago. My 1st ride I thought there was a vibration in my feet. I noticed it right away. I didn't use the thick washer on the crossover tube clamp. With this washer it didn't allow the pipe be be held tight, so I went without it. I figured if I went with it, it would make rattling noise.
Old May 24, 2013 | 08:20 AM
ddm502001's Avatar
ddm502001
Our RUG is headed into the shop this morning, for the same issue, not sure what it is causing the resonance but whatever it is is worsening and backing screws and bolts out fairly often. Reminding me of the 56 panhead I owned where I had to tighten bolts at every stop..
Old May 26, 2013 | 07:55 AM
TMOUT's Avatar
TMOUT
So I backed off the bolt on the crossover pipe mount a bit, seems that was the problem. The decel vibration is gone. Never would have thought of that, man this forum is handy!!
eross318
2014-2024 Touring Models
Mar 14, 2018 01:44 PM
rnrobert
Engine Mechanical Topics
Oct 11, 2017 05:52 PM
P51Driver
Nov 13, 2012 09:11 PM
coronerrpm
Nov 8, 2010 11:18 PM
Wide06
Jan 1, 2007 12:13 AM
