Exhaust question
Old Jun 9, 2013 | 08:53 PM
Birdman2778's Avatar
Birdman2778
Default Exhaust question
I have a 2013 Road King and had the dealer install a Stage 1 kit, V&H monster rounds, and a Fuelpak. I noticed that the left exhaust pipe is more discolored than the right one (running rich?). I just hit 600 miles and was wondering if its a map issue or does it need to be brought in and looked at? Would like to avoid leaving it at the dealer for anfew days if i can. Thanks in advance for any help
Old Jun 9, 2013 | 09:46 PM
Dakotazeb's Avatar
Dakotazeb
Generally the discoloration on mufflers is caused by your bike running too lean. It's definitely a tuning issue. My guess is that something is not set correctly in the FuelPak.
Old Jun 9, 2013 | 09:49 PM
DannyZ71's Avatar
DannyZ71
Do you have a picture? MR mufflers shouldn't show any discoloration because what you see mostly is the chrome heat shield covering it. Or are you talking about the head pipes, which also have heat shields?
If they are getting that hot, to discolor the heat shields, you have a major issue in my opinion.
Old Jun 9, 2013 | 10:01 PM
Birdman2778
I should have clarified. Its the tips when you look into the opening. I will take a pic tmrw when its light out. Thanks for the input so far guys
Old Jun 10, 2013 | 02:09 PM
0ldhippie's Avatar
0ldhippie
Left side runs cooler = normal
Old Jun 11, 2013 | 08:25 AM
Dakotazeb's Avatar
Dakotazeb
If you are referring to a discoloration on the inside of the end caps on the Monster Rounds I had the same thing happen to a set of Monster Ovals. It's just film from the exhaust gases and if you use a cleaner it will come right off. At first I thought the end caps were discoloring but I was able to remove the film.
Old Jun 11, 2013 | 09:50 AM
DrWalkinboner's Avatar
DrWalkinboner
Same thing with mine and I put up a thread too https://www.hdforums.com/forum/touri...t-slip-on.html
I got my 10k service and my indy checked my plugs and said they look fine so there was no tuning issue with it running rich/lean. I think Dakotazeb is right though, I took some Never-Dull to it and it came right off.
Deftone5
Jun 14, 2022 02:03 AM
Rollon
May 20, 2017 12:16 AM
KyBourbon
Mar 18, 2015 12:48 AM
BBSHK
Apr 12, 2014 04:25 AM
Spinner18
Jul 6, 2012 07:30 PM
