Stock mufflers
Old Jun 19, 2013 | 10:29 PM
smithbrl's Avatar
smithbrl
Default Stock mufflers
I just put my stock mufflers back on my 09 Ultra and it seems like the left pipe has more exhaust output than the right. The left muffler has what looks like a "plug" in it while the right muffler looks wide open.
I thought the right one should have more output. Could I have the mufflers reversed?
Thanks
Old Jun 19, 2013 | 10:42 PM
mmcbeat's Avatar
mmcbeat
In stock form about 70% of the exhaust comes out the right side.
Old Jun 20, 2013 | 06:04 AM
modes's Avatar
modes
My stock pipes have an indent on the inside for bottom shock mount clearance. Not sure about the new style frame bikes, but it is a dead give away which goes on which side.
Adam
Old Jun 20, 2013 | 06:37 AM
Bullitt59's Avatar
Bullitt59
My 2011 Ultra Classic has the same exhaust, emtpy on the right side and a plug on the left. Tech at the dealer said it may have something to do with the catalytic converters, which doesn't make any sense to me.
Old Jun 20, 2013 | 09:58 AM
RollaMo's Avatar
RollaMo
Thanks
Would be very obvious if you have the mufflers reversed.
On the inside of each muffler is an "indent" to clear the lower shock mounting bolt.
If you reverse the mufflers, they would look funny with that indent on the outside.
Adam
Current bikes are the same way.
Old Jun 20, 2013 | 02:31 PM
smithbrl's Avatar
smithbrl
Yeah, the indents are to the inside so they're on there right. I just don't understand why there's more exhaust from the left side-I thought it was the other way around.
Thanks
Old Jun 20, 2013 | 02:35 PM
KCFLHRC's Avatar
KCFLHRC
Thanks
It is the other way around, maybe you have a critter stuck in the right one.
Old Jun 20, 2013 | 07:38 PM
smithbrl's Avatar
smithbrl
You may be right. The sat up for about 3 yrs.
Maybe I'll just put the Jackpots back on.
Old Jun 20, 2013 | 07:48 PM
Def Mute's Avatar
Def Mute
Fill the tank and go for a ride...
When you smell dead burning rat, you've found your problem!
Old Jun 20, 2013 | 08:31 PM
bikerlaw's Avatar
bikerlaw
I still have the stock mufflers on my 2013 with the stock cats. I "had" the plug on both mufflers. I know this because I just took my trusty hole saw and 12 inch extension and drilled them both out. Maybe one of your plugs got drilled out as well.
blarg
Nov 25, 2014 03:43 PM
mrfikser
Mar 14, 2012 11:22 AM
RK2010
Apr 10, 2011 09:17 PM
OLD 96
Exhaust System Topics
Jun 11, 2009 03:42 PM
sugarbear
Jul 29, 2007 10:54 AM
