Improve performance on FLHTC
Old Jun 21, 2013 | 11:04 PM
D.Chavez's Avatar
D.Chavez
6th Gear
Default Improve performance on FLHTC
I am the proud owner of a 2007 FLHTC, it has 48k miles and is totally stock. I am wanting better performance and a bit more power out of it. Does anyone have any input on dynojet or any thing else that might improve performance. I am not looking to ride like a bat out of hell but I would like abit more power on the highway and around town. Any suggestions appreciated.
Old Jun 22, 2013 | 03:36 AM
Timmy B's Avatar
Timmy B
From: 12 year, Colombia, 4 years Mexico, currently In Kuwait, but Boston is HOME!!
if the bike is stock, stage one and two then see how you feel then keep on going, Ride safe!
Old Jun 22, 2013 | 03:46 AM
mkguitar's Avatar
mkguitar
yes, do some research on a stage 1 kit.
you can spend anywhere from $400 to $2000 depending on your skills and what parts you choose.
generally you will gain 7 to 10 horsepower ( 10%+) with out loosing reliability or MPG.
read up
mike
Old Jun 22, 2013 | 03:48 AM
Stiggy's Avatar
Stiggy
The first dollars you spend result in the greatest return on your money. Stage II (in my case,) resulted in HP jumping to 85 and torque close to 95 ft/lbs. That's nearly 30% over stock. It involves new pistons, cams, high flow air cleaner. your choice of exhaust and an ECM remap. No head work involved, and can be had for around $2,000 in parts.
Remember, you've got the '07 with the weakest crank HD ever installed. ( They even changed vendors for the '08 model year after it was discovered.) So I wouldn't go too much farther than that until I addressed that issue too.
Old Jun 22, 2013 | 06:50 AM
katobird's Avatar
katobird
Air cleaner, power vision...plenty of power.
all that stage crap, cams, etc, etc, is a waste for me.
Old Jun 22, 2013 | 07:02 AM
glide2005's Avatar
glide2005
On my 2010 EGC, I installed Andrews 54 cams, CNC ported 103 head/w ACR, TTS mastertuner, stage 1 A/C, catless head pipes, and American Custom slip-ons. I used the 54 cams because the noise level on the exhaust doesn't change much. I went from 69hp and 72lb tq, to 96hp and 96lb tq. The tuner at the dyno said I could get more tq with better exhaust. But the couple of lb's of tq to me is not worth the extra expense for new pipes.
Old Jun 22, 2013 | 07:39 AM
billnourse's Avatar
billnourse
I put on a SE air cleaner, Rinehart mufflers and PC V tuner and gained about 11 HP.
Bill
Old Jun 22, 2013 | 07:53 AM
jus2anoyu's Avatar
jus2anoyu
Mufflers, air cleaner, tuner and cams. It'll be like having a new bike again.
Old Jun 22, 2013 | 10:48 AM
0ldhippie's Avatar
0ldhippie
Stage 1 (A/C, Slipons + tuner/tune) will get about a 10% improvement in power. Adding cams can give ya 30% over stock with good reliability. IMHO pushing over 100hp with a stock pressed crank is asking for trouble.
Old Jun 22, 2013 | 12:39 PM
oldhippie's Avatar
oldhippie
Default FuelMoto USA
I have the solution for you. Go to fuelmotousa and buy one of the Powerpackages. Air cleaner, slip ons and Dynojet PowerVision. I love mine, have 47+K on it and it is running like a raped ape.
I like the Supertrapp SE mufflers, they are low, deep and don't over power you at cruise speed but they bark when you get on on the throttle.
The overall system will give you much better power, especially from 1900rpm through to 5K but best where you need it most down low.
Not only that the bike will run much cooler.
I would also suggest you invest in the IDS drive sprocket if you dont already have it. It will give you much smoother ride. It was a etrofit for the 07s when they added it to the standard bike for the 08s.
ThePaintPirate
Jul 31, 2017 12:54 PM
jbrooksca
2014-2024 Touring Models
22
Jun 14, 2016 03:26 PM
Indy Road Dog
Exhaust System Topics
Jul 18, 2011 08:43 AM
jeffnvegas
Jun 15, 2011 01:49 PM
zak
Aug 5, 2006 08:10 PM
