Front brake issues
Old Jun 23, 2013 | 02:32 PM
Kadorja's Avatar
Kadorja
Default Front brake issues
So the last couple of weeks my front brakes on my 04 Road King went from being soft to almost completely dead. I bled the system a couple of times and finally flushed it completely and it still has the same issue. I can pump the front brake handle and it works great but once I ride a couple of feet it goes all the way down to the grip unless I pump it back up again.
Took it to the dealership today and they bled the system and still has the same issue. It feels a little bit better but they said they think I need a new master cylinder and new brake lines plus they wanted to pull and clean the calipers. $600 worth of parts and labor.
I'm thinking about just buying a master cylinder rebuild kit and either stainless front lines or just going with the stock black lines and cleaning out the calipers myself. Maybe $150 worth of parts and free labor.
Anyone else have any ideas or suggestions? I read up on turning the handlebars and holding the lever tight all night and then tapping the master cylinder but I just saw that suggestion today so maybe tonight I can try it. Otherwise I have flushed the system and tried to bleed it normally and with a vacuum bleeder.
Old Jun 23, 2013 | 02:46 PM
ke5rbd's Avatar
ke5rbd
The master cylinder is by passing the fluid. You need a new master cylinder. If it still feels soft after new Master cylinder I would replace the brake lines. The calipers will make the brakes stick and not work or will drag. Brake fluid is an excellent paint stripper also.
Old Jun 23, 2013 | 02:57 PM
KiloGolf4's Avatar
KiloGolf4
For a couple hundred bucks, you can upgrade the entire brake system to the '08 brembo set up. MC, lines, calipers, and rotors from here or ebay should only set you back $300 or so if you shop around.
I just did this to my '03EGC and highly recommend it!
Old Jun 23, 2013 | 03:01 PM
basselope's Avatar
basselope
Brake lines expanding when you apply the brakes will make them feel spongy. If you aren't losing fluid, the master cylinder is almost certainly the cause of your brakes losing that much lever (pedal). Flushing can't always get all the gunk out and, of course, can't do anything for a worn out or damaged seal. If you rebuild your own cylinder and calipers, make sure you inspect the walls closely to make sure there is no pitting or hard deposits that could render your efforts pointless. When you are done and happy with the results, consider doing the rear as well. It has been through all the same miles as the front and is likely in the same condition.
Old Jun 23, 2013 | 03:04 PM
103 sedona orange's Avatar
103 sedona orange
Going the cheap way on brakes may not be the SAFEST. Do it the correct way, whatever the price tag. Good luck.
Old Jun 23, 2013 | 03:19 PM
Kadorja's Avatar
Kadorja
I figured it would probably be a bad seal or the line expanding. The bike is fairly old and it just slowly started to go bad over the past week. The rear may take some time to get around to doing. All my air ride stuff is on the right side bag so I would have to pull it all out which isn't hard I just have to be careful with it.
I wouldn't say I'm going 'cheap' with buying a rebuild kit and new lines. Certainly will save money but that's being smart and not cheap. Getting a cheap product that isn't the same quality as OEM is way different than a rebuild kit and better lines. I'm 100% sure a good rebuild kit is as good if not better than stock as long as it's done right. Stainless lines are always going to be better than the stock rubber as well. I'm comfortable doing my own work correctly and saving some money as well.
Old Jun 23, 2013 | 03:50 PM
Harleypingman's Avatar
Harleypingman
What often happens is the caliper pistons can't move freely due to crud building up so it takes more pressure to move them causing more m/c wear and swelling of the rubber lines.
So for sure you should get the HD caliper rebuild kit, replace the lines and rebuild the m/c.
Now, if you want a dramatic increase in braking power, do a complete Brembo swap.
Carl
Old Jun 23, 2013 | 03:53 PM
Harleypingman
Also, there is a minimum thickness sped embossed in the rotors. Confirm that your rotor thickness is okay.
Carl
Old Jun 23, 2013 | 04:47 PM
Kadorja's Avatar
Kadorja
Carl
Rotors look almost brand new. Bike only has about 20k miles but I am very surprised how well the rotors are doing. The front pads where recently replaced at the dealership so everything should be doing alright. Hopefully they would of cleaned them out a little or told me they looked bad but if the master cylinder rebuild doesn't fix it I'm going with new lines and trying to clean or rebuild the calipers.
Old Jun 23, 2013 | 04:51 PM
BoonDock_Saint's Avatar
BoonDock_Saint
You're right. Start with rebuilding the master.
