flhx etc grip/spring adjust or replace
Old Jun 24, 2013 | 10:21 PM
gchalifo's Avatar
gchalifo
Default flhx etc grip/spring adjust or replace
Hey all
So I am looking potentially replacing or adjusting the throttle/return spring on my new flhx just to ease up on my old wrists....
anyone? experience with tthis....is there an adjustment to ease up on the throttle tension? or a lighter return spring that can be swapped out?
thanks/g
Old Jun 24, 2013 | 10:24 PM
jdvorchak's Avatar
jdvorchak
When was the last time you lubed the throttle cables? I'd try that first. You will be amazed at how easy the pull will get.
Old Jun 24, 2013 | 10:34 PM
gchalifo's Avatar
gchalifo
this is a 2013, with less than 1k miles on it, brand new....and it's the new drive by wire, so I am assuming no cables, only wires to the throttle, then some sort of return spring within the throttle handle assembly.....just wondering if the tension is adjustable....or can be eased up somehow.....thanks....
Old Jun 25, 2013 | 12:35 AM
jdvorchak's Avatar
jdvorchak
Ok you didn't mention the year and model unless I missed it. Sorry I don't know if the tension is adjustable. since it's that new I'd suggest asking the dealer. My 2010 seems a little hard to pull as well so I'd be interested in what you find out. I just use the cruise control a lot.. And I mean a lot!
Old Jun 25, 2013 | 01:04 AM
0ldhippie's Avatar
0ldhippie
Cruise control is your friend! Pretty sure your throttle tension is not adjustable.
olongapo1
Apr 12, 2014 06:43 PM
ahorsewithnoname
Sep 19, 2010 06:32 PM
STARRY
Jun 1, 2010 08:00 AM
gambueller1
May 19, 2010 07:36 AM
jon0808
18
Feb 23, 2008 08:05 AM
