hard starting [thundermax] ?
Old Jun 27, 2013 | 09:54 PM
garyFLHPI's Avatar
garyFLHPI
You very welcome! Hope it works for you!
Old Jun 1, 2018 | 11:08 AM
RoadKing1956's Avatar
RoadKing1956
Stage II
Default Same issue
Did you ever get this issue fixed? I’m having same since auto tune has been carried out.
Old Jul 19, 2018 | 09:20 AM
Sal-on-Cam's Avatar
Sal-on-Cam
1st Gear
Default Lower rider S 2017
I’m have the same hard start issue. Mostly when it’s cold. Cranks over once n then seems like it’s almost getting compression locked for a second n then continues turning n fires right up. Seems to happen less when the motor is warm. I have a high lift cam rs576 n revolution 113ci installed with a 10.5:1 piston. I believe my corrected comp is only 9.6:1. I’ve reduced my tac from 80 to 60 n fuel squirt to 144. Starts strong but still goes to lockup sometimes.
Old Jul 19, 2018 | 09:31 AM
PFWiz's Avatar
PFWiz
Originally Posted by HDTimFLHX
Yeah, I think there is some adjustment for hard starts. I think it cuts the fuel or add more for a split second while firing up.
I really like my Dragula 2into1. It isn't real loud while cruising, which I like because it isn't obnoxious or anything, but has a nice throaty bark when I get into the throttle. I'm pretty sure it's the 2.55 baffle.
*This*
There is also a setting for the compression release.
Not to give you a hard a time, but you really need to be a little "hands on" to get the most out of a TM. You can adjust fuel to increase mpg, add fuel to get rid of pinging, check your fault codes and history...etc. You really need to have a laptop, a cheapo $150 used one from Ebay is plenty. I used to check my tune every 500 to 1000 miles (on my 2011 RGU).
I also had a Dragula with 2.55 baffle and was very happy with it.
Old Jul 20, 2018 | 12:04 PM
skydude426's Avatar
skydude426
Originally Posted by PFWiz
*This*
i agree. I have a Thunder Max on two bikes and they work great but you might have to make some adjustments for hard starting, pinging, decel pop and the like. It's not hard, you just have to first have a laptop and second do a little reading. If you download and open the software for your Thunder Max, there is I think a tab called help or documentation. In there you can find help suggestions for a particular problem or the entire manual is available.
My bikes run great and I don't need to pay for someone else to tune them that may or may not know what they are doing. Like most things, to get the most out of it, you have to take some initiative and get more involved with it. A good tune, even with an auto tune device, is rarely plug and play and walk away.
Old Jul 21, 2018 | 08:59 AM
Sauraus's Avatar
Sauraus
I have the same issue, just finished rebuilding my wife’s 2013 FLS, with a 107ci S&S big-bore kit, 89cc S&S heads, MR103CE cams, 58mm S&S throttle body and Fueling 9944 injectors.
Bike turns over, but the only thing I get is very very loud bang in the exhaust. I sent a support file to TM yesterday but maybe someone here knows something?
TexasMotorcycleRider
2014-2024 Touring Models
11
Sep 24, 2018 10:31 AM
SilverEagle50
Dec 4, 2014 07:08 AM
slammed05fatty
Jul 11, 2013 01:05 PM
Renold
Mar 18, 2013 09:14 PM
kdietz
Jul 21, 2007 04:51 PM
