SE 255 Install Started
Old Jul 10, 2013 | 04:17 PM
  #31
Watchfuliz's Avatar
Watchfuliz
32 at speed is normal, 6 at idle when hot. These are high flow, low pressure systems.
Old Jul 10, 2013 | 04:34 PM
  #32
nateuofmn's Avatar
nateuofmn
I'm going to take it out later and see how it does, but the engine light still worries me.
Old Jul 10, 2013 | 05:00 PM
  #33
nateuofmn's Avatar
nateuofmn
Just me being paranoid. Oil temp went back to normal.
Old Jul 10, 2013 | 06:02 PM
  #34
hattitude's Avatar
hattitude
Originally Posted by nateuofmn
My check engine light does stay on for about 5 seconds after the bike is running and then goes off, wondering if this is because I started with the 02 sensor and intake unplugged before, or the previous tune?
When a check engine light comes on after engine start and then goes off after a few seconds, it is telling you there is an old "history" code stored on the ECM. If you clear the code, and the problem does not come back, you will not see the check engine light again....
It is most probably a history code related to the sensors being unplugged when you did your start up.... the code will tell you what the issue was...
Old Jul 10, 2013 | 07:19 PM
  #35
nateuofmn's Avatar
nateuofmn
Kind of what I was thinking. Is unplugging the battery for a little while going to clear it?
Old Jul 10, 2013 | 08:19 PM
  #36
BoonDock_Saint's Avatar
BoonDock_Saint
No, but this will:
https://www.hdforums.com/forum/dyna-...lear-them.html
Old Jul 10, 2013 | 08:47 PM
  #37
nateuofmn's Avatar
nateuofmn
Originally Posted by BoonDock_Saint
Thank you, a lot of steps but I'll be doing that tomorrow.
Old Jul 11, 2013 | 06:03 PM
  #38
nateuofmn's Avatar
nateuofmn
Decided to properly get the bike tuned on a dyno. We'll see how it goes.
Old Jul 11, 2013 | 06:06 PM
  #39
sanman4ever's Avatar
sanman4ever
Probably going to be your best bet...are you using a HD dealership or an indy to perform the dyno and what is the cost?
Thanks
Old Jul 11, 2013 | 06:25 PM
  #40
nateuofmn's Avatar
nateuofmn
Using an Indy, $300 cash for custom map build. Never had a bike dynoed, will I get the map download on a cd after or something?
