Radio LCD dispay
Old Jul 8, 2013 | 02:09 PM
Chirobud's Avatar
Chirobud
Stage III
Default Radio LCD dispay
2006 Bagger, last Wed. the LCD display on my receiver went blank. The radio still works fine, and I can navigate through it blindly to access the functions. I notice that it is still backlit in the darkness of the garage. Fuses are fine. I took it out and inspected it (like I knew what I was doing?) but couldn't figure anything out. Anyone have any ideas why an LCD display stops displaying?
IN the dark
Old Jul 8, 2013 | 03:08 PM
jps9287's Avatar
jps9287
IRON CROSS AUDIO!!! I bought my 2006 street glide with this exact same problem got in touch with these guys and they said the 2006 was known for this problem 4-5 days and $250 dollars later my radio works flawlessly!!!
Old Jul 8, 2013 | 04:21 PM
Lowcountry Joe's Avatar
Lowcountry Joe
You checked fuses? You took it out? What "bagger" do you have??
Old Jul 8, 2013 | 04:44 PM
kfstreetglide's Avatar
kfstreetglide
Try this thread might work and save a few bucks
https://www.hdforums.com/forum/touri...=HARMON+KARDON
Old Jul 8, 2013 | 05:17 PM
timvan's Avatar
timvan
IN the dark
Just sent my 09 radio in for the same.. I was told that it's likely electrical related.. Too much or too little voltage.
My case the internal amp failed, likely causing the voltage fluctuations... Fingers crossed.
Old Jul 8, 2013 | 05:42 PM
K Melancon's Avatar
K Melancon
Check your brightness setting
Old Jul 8, 2013 | 07:03 PM
Cosmic Charlie's Avatar
Cosmic Charlie
YES ... this is simple & free
I agree - as a good start ...
Iron Cross is option #2 ....
Old Jul 9, 2013 | 08:33 AM
Chirobud's Avatar
Chirobud
Stage III
Default Lcd
Fuses were fine, changed with new anyway. Removed radio, disassembled to the point of removing LCD unit away from the circuit board immediately behind/attached to it. Noticed some discoloration which looked like it could have been mold, and cleaned it with alcohol and a Q-Tip. It looked better, but not perfect when I was done. Re-assembled and re-installed but there was no improvement (just happy I didn't wreck anything).
My bike is a 2006 UltraClassic.
Old Jul 9, 2013 | 08:44 PM
Lowcountry Joe
A recent thread talked about intermittent contact between the pins where the display board plug connects to the main board. The author very slightly bent the pins to provide better contact. Fixed his display issues.
St Glide
May 13, 2012 10:33 PM
mastied
Dec 30, 2010 02:29 PM
FiremanJeff
Nov 13, 2010 07:02 PM
txbuttset
Apr 13, 2009 04:10 PM
Kuffs565
Jul 17, 2006 07:34 PM
