Hayden at 3000 miles
Old Dec 4, 2014 | 05:07 PM
  #171
cmashark's Avatar
cmashark
I wanted to get a Hayden for mine... Just couldn't buy into it. Stemmed to gimmicky to me. I ended up ordering a Baker Attitude Adjuster. Once my new crank gets here, I will assemble my 113 and install it.
Old Dec 4, 2014 | 06:24 PM
  #172
shakrr's Avatar
shakrr
my 3 year old hayden with both springs works great on my 02 over 13000 miles with minimum wear like others in this thread
Old Dec 4, 2014 | 06:41 PM
  #173
sanman4ever's Avatar
sanman4ever
Your good because you have an 02.
The Hayden sucks it on the newer bikes. Running the Hayden on an 09 and up makes the chain way to tight.
Old Dec 4, 2014 | 06:46 PM
  #174
dawg's Avatar
dawg
Originally Posted by soos
This thread scares me. I have been sitting on a Hayden swap for the past year. Every time I find the time to do the job, this thread gets resurrected. Seems like this is an omen...
Pffft
Old Dec 4, 2014 | 06:57 PM
  #175
soos's Avatar
soos
Originally Posted by dawg
Pffft
Another farkin' country heard from...
Old Dec 4, 2014 | 08:02 PM
  #176
seniorsuperglideE8's Avatar
seniorsuperglideE8
Wow! What timing, I just got a reply from Hayden and they said they are changing the springs in their product. By the way the rollers ate into my adjuster shoe and plastic was literally melting away. I reinstalled my stock adjuster, for now till the "new and improved" product is sent to me.
Old Dec 5, 2014 | 03:04 AM
  #177
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
Are you sure they are willing to change their springs ?
My primary is as smooth as can be using only the "current" outer spring from their kit. I have 20W-60 mineral oil in there (for queuing in traffic) and don't need to worry about heat collection on the bearing race inside the clutch basket.
Old Dec 5, 2014 | 06:11 AM
  #178
Notgrownup's Avatar
Notgrownup
I have About 5000 miles on my Hayden, plan on checking when I get a chance but it runs good to me, I hear a little whirring sound but not very alarming... I took it on a trip into Canada this summer so I had a bit of trust into it....88000 miles on the bike so the chain might be polished good to where it doesn't wear in the shoe like a new chain...
Old Dec 16, 2014 | 11:15 AM
  #179
hattitude's Avatar
hattitude
I bought an M6-BT07 for my '12 Limited in Dec 2012. It was the new style M6. I procrastinated swapping it for the stock tensioner.
During that time, I read numerous threads about it being too tight on the newer bikes and there were questions about the spring compression being 3/8" or 1/2". Some measured it at 1/4".
This all made me leery of installing the Hayden and I just put it on a shelf.
I read post #177 in this thread and wrote to Hayden. I mentioned I bought one of their units (included a copy of my receipt), read it was too tight for newer bikes, didn't install it because of tightness concerns, heard they changed the springs, and asked if there were new springs, could I get some.
They said they would send me the new springs.
I got the springs today and they are definitely different from the ones that came with the Hayden in 12/2012.
Here are the springs, separated, side-by-side. The original Hayden springs are on your left and the newer springs on your right.
Here is a pic of the springs stacked as they would be in the shoe. The original on your left and the new on your right.
With my scientific finger test... The springs feel as if they are similar in strength, the newer ones just seem to be made shorter..
I took these measurements;
Original outer spring - 1.35 inches
New outer spring- 1.12 inches
Original inner spring - 1.58 inches
New outer spring - 1.36 inches
I am in the middle of building a shop to work on my bikes, it won't be completed for about another month. I won't be able to install the Hayden, with the new springs, until then. I'll be interested to see what the spring compression will be...
I thought I would post this info for those who believe their Hayden is too tight, or those who gave up on the Hayden because of the questions about the springs.
I'm pretty impressed that Hayden made a correction/update in response to feedback about their product and that they sent me the springs at no charge.
I'll post back when I finally get this thing installed and how it fits....
Old Dec 16, 2014 | 12:42 PM
  #180
UltraNutZ's Avatar
UltraNutZ
had the same issues and a NOISEY/WHINEY primary for some 2000 miles. Pulled the damn thing out and went back to stock and did exactly what oldhippie did based on recommendations from several reputable builders with a small tack to hold it in place at the proper adjustment.
Every 3000 miles I pull the primary just to check everything in there. All is good, no noise, no over-tightened chain, etc.
