Help to identify please. Unknown cable?
Old Jul 10, 2013 | 07:25 PM
Deadwood's Avatar
Deadwood
Default Help to identify please. Unknown cable?
Hi, recently purchased 09 RKC and not sure what this cable that is hanging down from behind left hand side of headlight shroud.
Any ideas?
Old Jul 10, 2013 | 08:33 PM
2-Piece's Avatar
2-Piece
I believe that connector is for one of the accessory switches on the back of the nacelle. Do all the lights on the front end work?
Old Jul 10, 2013 | 09:50 PM
Deadwood's Avatar
Deadwood
Yeah, all the front end lights work which are operated by the toggle switch on the right hand side, this connector hangs from below the left hand side.
As I understand the toggle switch on the left is for an accessory (if/when added) so it may have been connected to some GPS unit? Got me beat.
Old Jul 10, 2013 | 10:31 PM
Onramp's Avatar
Onramp
I know there are a lot of unused cables on my bike, like one that should go to an alarm speaker. Could that be for heated hand grips? Next time you have the front part of the fairing off, track it back to whatever it hooks into, and check the service manual to see what it goes to. In the meantime, get it out of the weather...
Old Jul 10, 2013 | 11:50 PM
Redbeard719's Avatar
Redbeard719
If you remove the headlight from the nacelle, you'll find its mate. Since you're passing lights work, it is for your accessory switch. The white connectors allow for easy disconnection/removal of the nacelle halves.
Old Jul 13, 2013 | 08:46 AM
Deadwood's Avatar
Deadwood
Ok so had some spare time this arvo and removed the headlight to search for the other end of the connector hanging down in the photo and that white connector is connected to the toggle switch on the left hand side however I couldn't find a disconnected connector to join it to, any ideas as previous owner is uncontactable?
Old Jul 13, 2013 | 09:27 AM
mkguitar's Avatar
mkguitar
what colour wires go to the plug?
that would allow tracing through a wiring diagram
mike
Old Jul 13, 2013 | 09:28 AM
ndnguyd's Avatar
ndnguyd
It doesnt connect to anything.
Old Jul 13, 2013 | 10:35 AM
skully1200's Avatar
skully1200
It is for your choice of accessories that you don't have any of. Mine is hooked to an auxiliary 12 volt outlet. If you currently have no use for it, just tuck it back up in the nacelle.
Old Jul 13, 2013 | 06:12 PM
Deadwood's Avatar
Deadwood
Thanks guys, the previous owner did a bit of touring so wonder if he had a GPS set up happening. Handy to know I can use this for a future accessory. Cheers.
Softailman04
Aug 30, 2018 06:31 AM
Twitch98
May 6, 2018 07:29 PM
kelton3
May 1, 2008 07:16 PM
StreetKing
Jun 29, 2007 11:25 PM
jackster007
Apr 8, 2006 11:25 AM
