The Tuner thread
Old Jul 13, 2013 | 02:57 PM
09FLHT's Avatar
09FLHT
Default The Tuner thread
OK. Its been awhile since Ive seen a tuner thread, so post up.
Whats your favorite tuner. Oh. And does it do just fuel or does it do timing too?
Old Jul 13, 2013 | 02:59 PM
rooti's Avatar
rooti
TTS, has more adjustments then any other tuner on the market. The best dyno tuners in the world will tell you to get TTS
Old Jul 13, 2013 | 03:02 PM
mkguitar's Avatar
mkguitar
I use the nightrider.com XIED.
while not a "tuner", it does offer compensation for a free flowing intake and exhaust, slightly richening the air fuel mixture by about 8% under most conditions.
cost about $125
ignition timing, rev limit etc are all retained at stock parameters
The xieds are a simple resistor pack plugged inline with the o2 sensors, these "fool" the stock ecm into richening the mixture
suitable for a stage 1, not the ticket for cams or other mechanical performance improvements ( stage 2, 3, 4 etc)
Mike
Old Jul 13, 2013 | 05:58 PM
TUCCI's Avatar
TUCCI
PCV here.....you can change the fuel across all RPM ranges as well as the timing which is pretty handy if your motor starts to ping at some point. I could put the AT on it but it already runs like a raped ape so why bother.
Old Jul 13, 2013 | 06:04 PM
skully1200's Avatar
skully1200
I am running the PC-V. I will be hooking up my auto tune tomorrow, along with new exhaust, and right now I feel like a kid on Christmas Eve.
Old Jul 13, 2013 | 09:25 PM
ke5rbd's Avatar
ke5rbd
Have you or your tuner ever looked at a SEPST or a Power Vision. They all have the same adjustments. In fact you can copy from one and paste in the other. The TTS does have some good canned maps and so does the SEPST. The power vision is starting to catch up on the maps. As far as being more useful and easier to use the Power Vision is my choice. You can monitor functions and do autotuning without a computer. You can do quick tune functions with out a computer. They all three have a compare tool, but again the PV is much more user friendly with the Delta function. I haven't found the Smooth function on anything but the PV. It does exactly what it says, makes real smooth running.
Old Jul 13, 2013 | 09:34 PM
madhunter60's Avatar
madhunter60
+1 dynojet Power Vision, hands down.
Old Jul 13, 2013 | 09:36 PM
Rdgray's Avatar
Rdgray
I have the Power Vision. The thing I really like about the PV is leaving on the bike and monitoring what's going on at all times. I can store 6 tunes in it and pull over and flash the ECM at anytime with another map if I want more performance or better fuel economy.
Old Jul 13, 2013 | 09:41 PM
FLHTCU Owner's Avatar
FLHTCU Owner
I've had a few, (Cobra Fi2000, SESPT) and now the T-Max With the T-Max my bike is running better than it ever has. The initial price is more, but from my experience it's worth it.
Old Jul 13, 2013 | 09:49 PM
Orange&Black's Avatar
Orange&Black
I'm running the thundermax and very pleased !
