Crashed and burned!!!!
Old Jul 17, 2013 | 02:04 AM
tekeum's Avatar
tekeum
Originally Posted by smokinbutts
How did you already get a 3013? must be pretty bad *** with all the technology on it. I'm surprised it isnt a hover bike.
Lol 2013
Old Jul 17, 2013 | 02:14 AM
tekeum's Avatar
tekeum
How does someone test there ABS? If the frame is strait it sounds like it will get fixed. Every piece sheet metal will néed replaced except the rear fender. It flipped over a few times.
Old Jul 17, 2013 | 02:17 AM
Bikeagraman's Avatar
Bikeagraman
Wow, sorry to hear about that. Glad you and the mrs are okay.
Old Jul 17, 2013 | 02:18 AM
Sasquatch2727's Avatar
Sasquatch2727
What is it with deer? Humans have been running over them for a hundred years. You'd think they would have the danger imprinted in their DNA by now. They have those big freak ears that apparently can't hear a v-twin coming at them but try hunting them and step on a twig!
No, your ABS shouldn't let your front lock and GLAD you folks walked away.
Cheers!
Old Jul 17, 2013 | 02:37 AM
smithbrl's Avatar
smithbrl
I've had my front and rear brake systems flushed and refilled 2 times. Each time I picked it up from the dealer I went to the parking lot in the back. I check that the ABS light is flashing before I start moving. Then I check that the light goes out once I start moving.
If the light stays on solid I know there is an ABS problem. If all is well with the light I get the bike up to 10-15 mph and stand on the rear brake pedal. Then I turn around and get it back up to 10-15 mph and grab a handful of front brake lever. So far, the ABS has kicked in every time.
I also do this randomly a couple of times a year in a vacant portion of a parking lot .
Old Jul 17, 2013 | 04:25 AM
ddm502001's Avatar
ddm502001
Over 7K on our 2012, the front brake is touchy, the ABS works fine but the front can still nose dive sending the center of gravity off kilter pretty hard where I almost dumped in low speed harsh stops.
Sorry about your ride, and the riding partner. Buddy of mine went down last year where he and his wife got pretty banged up and she will not get back on one ever again. Personal choice where fear takes over, but just as with riding anything or having a bad encounter with anything the only way to shut it off is to get back on. I have bounced twice, did not like either time but got back in the saddle, still feels good to be there.
Hope your ride comes back, hoping your bride wakes up to enjoying the rides once again.
Old Jul 17, 2013 | 04:39 AM
mike5511's Avatar
mike5511
Unless you are completely incompetent, your odds of going down again have just went way up! It is statistically safer for your wife to ride now than before! (that ought to convince her......or tell her "that's O.K., it ain't no problem to find pretty girls to ride behind you on a Harley!!!"........I haven't tried this tactic yet so use caution!)
Old Jul 17, 2013 | 04:46 AM
brownfoxx1's Avatar
brownfoxx1
if you want to try out the ABS try stomping the rear brake, then try the front
Old Jul 17, 2013 | 05:09 AM
gunnyBob's Avatar
gunnyBob
As said I doubt that is an ABS fault... but never know!
As already said checking your ABS few time a year as explained is a good think, for the braking test be sure to be straight on and you shoudn't fail. I'v done it many times without problem!
Old Jul 17, 2013 | 05:24 AM
dwpmusic's Avatar
dwpmusic
I've had some close calls over the years with deer. Luckily, I've never hit one thanks to the Lord. Sorry about your mishap. Glad you or the wife weren't hurt. Hope she'll change her mind and get back on the bike.
