radio volume
Old Jul 21, 2013 | 04:16 PM
FOCI's Avatar
FOCI
Thumbs down radio volume
I have a 2006 flhxi and i noticed that the radio volume will by it self go from nothing to full volume at idle sitting still and then some times it is okay any thought?
Old Jul 21, 2013 | 04:32 PM
rkoivisto's Avatar
rkoivisto
Default volume
The most likely problem is the left hand thumb volume switch. Try taking it apart and use some contact cleaner on it.
Old Jul 21, 2013 | 09:31 PM
carrmat's Avatar
carrmat
Just had the same problem, I read a bunch on here that lots of people have had to replace the switch. First thing I'd try (since it worked for me) was spray a bunch of compressed air into the handlebar switch from every angle you can.
Old May 1, 2014 | 06:24 PM
FOCI's Avatar
FOCI
i was wondering is the switch easy to remove?
Old May 1, 2014 | 06:28 PM
mkguitar's Avatar
mkguitar
if you use contact cleaner, make sure it is plastic safe.
also check the speedo sensor is clean- the automatic volume control could be getting wacky info. try turning off the AVC
mike
Old May 2, 2014 | 08:11 AM
FOCI's Avatar
FOCI
i am goiong to try shutting off avc system first i will let you know how it goes
Old May 3, 2014 | 01:40 PM
FOCI's Avatar
FOCI
i shut off the avc and radio is working fine
Old May 3, 2014 | 02:49 PM
mkguitar's Avatar
mkguitar
great, if the speedo display is working properly, then the sensor and wiring is fine.
so the fault may be in the radio unit or the wiring to it ( from the TSSM, I think- I don't have an 06 wiring digram).
mike
papabear64
Aug 23, 2017 06:43 AM
SG-Jay
Audio Systems
Aug 14, 2017 08:20 PM
tinsnips
Jun 6, 2017 09:41 AM
hotshot
Aug 18, 2015 10:43 AM
greglcarlson
Feb 11, 2011 01:34 PM
