I posted this on the audio forum and thought I woujld try here.
I was in a good rainstorm the other day and notices I got a little water inside the fairing. I have been installing a amp and new speakers and had the lid off and noticed the water.
I invested and found the problem. The thin strip of rubber tape along the inside of the faring was torn loose in several places including where the 3 windshield screws go. I remember sometimes when you take the fating lid off that some of it sticks to the windshield. At least in the heat here in Texas.
I know I can order the foam tape from Harley but wondered if anyone had used something different that worked. I went to Autozone and bought some 3/16 inch camper mount foam tape but it's too thick. The Harley stuff is really thin. I did find some stuff on ebay that is 1mm thick that is probably close to what is needed.
Click on motorcycle add year go to windshield and part is listed. Might be able to help ya out. pretty cheap for a factory strip.
Yes, I knew I could order it from my dealer. I was just hoping to find something locally but to be honest I haven't checked with any of the dealer. Will probably do that and just order it.
All good was just my $.02
Good luck on sealing up that fairing.
I found a couple of local dealer that had the stuff in stock. Been taking the lid off several times adjusting an amp I was installing. The new stuff is already tearing a little. The problem is I wanted a shorted windshield and bought on out the cheapie s off eBay that is flat and you have to bend it. Hard to do without catching the foam seal and tearing it up.
