Neutral start safety switch
Old Jul 27, 2013 | 04:07 PM
pk54's Avatar
pk54
Default Neutral start safety switch
can a person disable the neutral start switch on a 2010 SG so it will start in gear with of course the clutch in? It's happened a couple of times where the engine killed starting out from stop light and I hate trying to find neutral in the middle of a intersection with people shaking their fists at me. I know that you aren't suppose to kill it but it happens.
Old Jul 27, 2013 | 04:58 PM
Ultra-Rick's Avatar
Ultra-Rick
You shouldn't have to put it in neutral, all you have to do is pull the clutch in and press the start button.
Old Jul 27, 2013 | 07:17 PM
RollaMo's Avatar
RollaMo
For a 2010 Street Glide, you can start it in any gear, if the clutch is pulled in.
With the clutch out, it has to be in neutral.
Old Jul 27, 2013 | 07:32 PM
ftworthcowboy's Avatar
ftworthcowboy
Same with my 2009 Electra Glide Classic.
Old Jul 27, 2013 | 07:48 PM
nitrohound's Avatar
nitrohound
Broke my switch changing grips, and now Have to start in nuetral. 09 flhrc
Old Jul 27, 2013 | 09:15 PM
skratch's Avatar
skratch
started in 2007.
if you've broken your switch, then it would probably be about the same degree of difficulty to bypass it as it would be to replace it.
Old Jul 27, 2013 | 09:26 PM
pk54's Avatar
pk54
After reading the replies that my bike should start in all gears with clutch in I went out and tried it again to make sure it won't and it won't. So is there a switch that is broke and where can I find this switch. Is it easy to replace? Thanks.
Old Jul 27, 2013 | 09:48 PM
cdestuck's Avatar
cdestuck
Inside the area of your clutch perch
Old Jul 28, 2013 | 07:33 AM
Ultra-Rick's Avatar
Ultra-Rick
First verify the correct clutch lever isinstalled. The correct style has a small ridge that contacts a microswitch inthe clutch perch. The older one without the ridge will fit. The wrong one mayhave been installed at one time.
jeffjackman
Oct 16, 2017 01:15 PM
Risky Rick
VRSC Models
Jun 5, 2016 04:46 PM
Steve Stayton
Feb 16, 2014 08:54 PM
TurkeyRun
Nov 12, 2012 09:44 AM
tloftus3
Apr 8, 2010 07:37 AM
