Why is my Street Glide Clutch Pull Waaay Harder Than my Softail?
Old Jul 31, 2013 | 06:41 PM
drspencer's Avatar
drspencer
Default Why is my Street Glide Clutch Pull Waaay Harder Than my Softail?
2007 Softail FXSTC, 17K miles
New SE compensator (most recent version), new HD Frictions & steels, HD clutch spring #37871-98A, HD Formula+.
This clutch is buttery-smooth, shifts perfectly, falls right into neutral without any effort, and doesn't slip.
No complaints, whatsoever.
2011 Street Glide FLHX, 15K miles
Exact same parts as above. However, this clutch has a significantly harder pull than my Softail. Shifts well, not too hard to find neutral, but not as nicely as it's counterpart. A little chattery at slow/cone friction zone speeds, too.
Both clutches have been adjusted using the exact same method, pretty confident I didn't overfill either primary case with Formula+.
My biggest complaint is the extra effort required to pull the Street Glide clutch lever. Is this due to the fact the SG clutch cable has to be force-fed through the inner fairing, where the Softail clutch cable just falls to its natural position, without any interference?
I should also mention that when I activate the Street Glide clutch, I can see the cable flexing ever so slightly where the adjuster joins the two pieces of cable.
Thanks
Old Jul 31, 2013 | 07:24 PM
Guitardude's Avatar
Guitardude
I notice a little difference between my FLHTCU and my FLSTCi, but really not enough to mention...
Old Jul 31, 2013 | 07:28 PM
av ultra's Avatar
av ultra
I think the touring models have a stiffer clutch spring, the 96 isn't too bad, the 103 has a stiffer spring, I know the se spring was a mother in my ultra.
Old Jul 31, 2013 | 07:32 PM
drspencer's Avatar
drspencer
If you read my original post, you will notice that both bikes have the same clutch spring.
Thanks
Old Jul 31, 2013 | 09:38 PM
uklauren's Avatar
uklauren
Florida Crew Moderator
My SE SG clutch is stiffer than my Heritage clutch but has improved a little with use, or maybe my left hand has got stronger. There is a product called a Clutch Wizard I've heard good things about.
Old Jul 31, 2013 | 10:20 PM
VinnyM's Avatar
VinnyM
My 13 SG is a little harder than my 11 Road King and the SG only has 1K on it. Both are 103's, I was thinking the cable running through the fairing may have something to do with it. May be putting the cable in a slight bind?..........just guessin!
Old Aug 1, 2013 | 04:07 AM
skully1200's Avatar
skully1200
I know they claim those newer clutch cables don't require lube, but any chance that cable needs some lube?
Old Aug 18, 2013 | 07:38 PM
SassyClifton's Avatar
SassyClifton
3rd Gear
I have a 2013 soft tail Slim with a 103, and the pull on the clutch is very stiff, compared to the 2007 FSLT with a 96. The parts guy at the HD dealer suggested a cable part that extends the attachment where the cable connects- says it adds leverage by 40% . Anybody have this added to their clutch ?
Old Aug 18, 2013 | 09:56 PM
1Canuck's Avatar
1Canuck
don't know but could the ramps be different
shankldu
Oct 1, 2017 07:09 AM
b2000s81
May 28, 2015 02:02 PM
ElectraBlack
May 13, 2014 10:07 AM
gartec81
Harley Davidson Videos
Apr 27, 2011 09:07 PM
outlawrider
Jun 19, 2009 07:30 AM
